Question about Moen & Replacement Cartridge
After consulting with Moen re: 2 knob Tub "cartridge" replacement, 12 yrs old, cold water not running, I did what I was told, after receiving the replacement cartridge 1248. (warranty replacement) The existing cartridge is "counter-sunk", ie 3 inches at least below the porcelain top deck of the tub. This installation includes an extension piece. The Cartridge and other "works" are inside an approx1 - 1/2 Brass Valve, which make a simple extraction of the original cartridge nearly impossible. I was instructed by Moen to tighten a long screw into the "old" cartridge leaving enough to connect to to pull the cartridge straight up and out. NOT POSSIBLE. this was described as a less than 1 hour job for the "beginner". I know have water running through to my lower level, cant stop the flow. Damage is catastrophic at this point (yes the water was off). I have now read that if the "cartridge" wont release from the original location, the the Valve must be replaced. I can't imagine how that can be done without destroying my tub. There is no access. Period. What is moen thinking of. I want the damage repaired, along with the "warranted" products.
  • lweljwel Dec 29, 2008
    Don't know if the previous message sent.
    I had said "Thank you!" I have a mess. I specifically asked
    Moen about the "tool" you mention. She told me no such
    tool existed for the situation I have. The cartridge will not come out. I have since read the "valve" must be replaced if the cartridge won't budge. There is no access to the valve (or cartridge for that matter). I am very unhappy with Moen. Any suggestions...
    no water..mess...$$$$....I have since turned off the water to the
    Hot water heater...the water was still trickling from the cartridge. I am on disability from cancer, blah blah blah....
    I can't seem to get these messages sent properly.
    The Moen rep specifically told me there was no tool for the counter-sunk cartridge in my tub. She instructed me to insert a long screw into the old cartridge and pull up and out.
    Won't come out.
    Scholar:
  • 68 Answers
If the water is off but still coming through, open a tap or two on one of the lower levels.
Basically the old stem does come out thru the top of the valve. Hopefully Moen sent you the tool to do this job. The tool is a 3/4"diameter about 4 inches long. Even on one end and two little tabs on the other.
Take the handle off stem. Remove the upper retaining nut, usually chrome. Pull out the two plastic upper stem pieces. Insert the 2 tabbed end into the stem area. You will feel the tab drop into the retainer ring. Slowly rotate the retainer ring out Counterclockwise. After the retainer ring is out then put the long screw in the stem and pull it out. Sometimes a little leverage helps here.
You will have TWO retainer nuts. The first one is easy just under the handle, the second will require the special insert tool.
Please rate this response and good luck, Phil
Posted on Dec 29, 2008
  • phil_m7 Dec 29, 2008
    Here ya go. It is cartridge removal tool # 14272. You will find it on the left hand side of this Link!
    http://www.moen.com/shared/pdf/6980pt.pd...
    Tell the people at Moen to well..............you know
    Here is a backup website then click on Illustrated Parts Diagram And it will take you to the PDF.
    Please rate this response and Good Luck, Phil
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    We had both the shower and the Bath tub remodeld and installed new Moen faucets with a single knob that turns right to left to open. All was fine for a couple of days but all of the sudden they startd...
    You need to install a new moen cartridge its a single handle posi-temp cartridge you should be able to get 1 for free if you are the original owner by calling 1-800-buy-moen more than likely when soldering in the new valve a little bit of solder broke free into the cartridge or hard water. When the water gets turned off and then turned back on it can break free alot of particles that can get jammed up in these cartridges or any fixture for that matter you will need a cartridge puller to perform this job with ease.
    Aug 27, 2011 | Moen & One Handle Tub & Shower Faucet
    I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
    The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
    May 13, 2010 | Moen & One Handle Tub & Shower Faucet
    Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
    Hello
    Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
    Off faces down
    Cold faces left
    Hot faces right
    Once in the position screw pastic knob back on.
    Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
    My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
    Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
    Contact Moen and describe your problem.
    Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
    My Mo's shower is about 6 years old. I think the
    Sure - there is always help at FixYa!
    This sounds like a bad cartridge. They can be replaced. To replace the cartridge:
    Turn off the water to the tub/shower.
    Remove the handle cover (it should pop off)
    Remove the center screw (usually phillips head)
    Remove the retaining clip holding cartridge in - you can use a pair of long nose piers or a small screwdriver
    Grab the cartridge with a pair of pliers and pull straight out. It may require a little force - there are O-rings around the cartridge to keep it from leaking.
    Check the cartridge bore (the hole where the cartridge was removed)
    Clean any debris or scale - lime away or CLR will work
    Apply a little bit of soap around the new cartridge to help it slide in easier. Push it all the way in and make sure it is seated. Re-install the clip (you should have received a new clip with the replacement cartridge)
    Turn the water back on a check for leaks
    If OK, reinstall the knob screw, and cap.
    Let Mom take her warm shower...:)
    Dec 13, 2009 | Moen & Posi-Temp Single Handle Shower Or...
    Replaced a moen cartidge and now the water is not hot in shower
    make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
    Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
    Moen single handle valve tub/shower
    The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
    A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
    As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
    Be sure that there is no particles of the old cartridge left in the valve.
    sanray
    Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
    Moen & Replacement Cartridge  Logo
    747 people viewed this question
    Top Moen Home Experts
    Mike
    john h
    Andrew Bugbee
    Are you a Moen Home Expert? Answer questions, earn points and help others
