Question about Acer Aspire™ T180 PC Desktop
I have a problem with cd/dvd drive,it opens and closes by itself all day.the computer model is Acer aspiret180.
  • 82 Answers
It look to me its a virus get on the net ad-ware personel and install it and let run
Posted on Dec 29, 2008
How do i open a disk drive to a acer aspire e touch
well it sounds to me like you are just trying to open the drive to insert a disk ? go to "computer" or "my computer" on the desktop, double click to open. you should see your hard drive "c" and cd/dvd drive "d" listed. right click the "d" drive, left click eject, voila. if you have more than one hard drive or a partitioned drive there might well be more drive letters but your cd/dvd drive will be marked as such. alternatively click "start", bottom left of desktop, click "computer" and once again you should see your drives listed. physically there should be , on the cd/dvd drive drawer itself a small button, push it once to open. failing all else, there should be a very small hole in the drive drawer, using say a paper clip or similar, insert into the small hole and push reasonably firmly, this should release the drawer manually and the drive will open. hope that helps. good luck.
May 11, 2014 | Acer Aspire 5315 Notebook
CD opens itself and closes
Either something is wrong with the physical open/close sensors, or there is a computer-virus on your computer that is intentionally causing the open/close actions.
May 31, 2010 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Driver dvd rw dvrtd08rs on my acer laptop says Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
UpperFilters
LowerFilters
UpperFilters.bak
LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Jan 28, 2010 | Acer Computers & Internet
CD tray not opeing
Perhaps it didn't fully latch so the CD drive doesn't think it's closed? Try opening and closing the door manually by straightening out a paperclip, then inserting it into the little hole in the front of the CD door. That should open it. Once open, close it and see if it will now open when you press the Open/Close button.
Aug 26, 2009 | Acer (KV.16X04.007) DVD Drive
My new hp computer cd rom open and closes itself, and its driving me wacko
Either you have a computer-virus that is sending "commands" to the optical drive to open/close, or you need to spend about $30 to buy a brand-new CD/DVD reader/writer.
Apr 22, 2009 | Compaq (224130-001) Internal 4x CD-ROM...
Slimtype dvd rw sosw-852s
Try This:
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
Feb 06, 2009 | Acer TravelMate 2700 Notebook
DVD-ROM
LS-120 SuperDisk drive help The LS120 will not work off a sound card IDE channel. ... If the computer is on, however, does not eject and you are running Windows 9x.
CD-ROM tray not opening See document CH000885 for additional information about why the CD-ROM or other disc tray ejects by itself or does not close.
CD or other disc tray does not close or opens by itself.
Good Luck, read and folow instructions/Please dont for get to Vote/Thank You.
Dec 26, 2007 | Toshiba A15-S1292 Notebook
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Acer Aspire™ T180 PC Desktop Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
