When I pour water into the engine, it spurts out with the same rate down under the engine block, its not thermostat, not thermostat housing, not the radiator hoses, could be freeze plug or head gasket but both should be fine i havent done anything unusual so far. Does anyone else encounter this issue before? now I cant drive because its completely dry in the coolant system,
SOURCE: 1995 Chrysler Cirrus overheating
Probably not water pump. Engine is notourious for vapour lock.
Cooling system must be blead of air before thermostat will work. Cool bottom rad hose is a dead give away. If you are still watching this forum reply , and I will walk you through the only way I know how to make it work properly. It's actually easy if you do it my way. I have worked on lots of cars , and this engine was the hardest to bleed out. Did one Yesterday , and works perfect.
Testimonial: "I need help on how to bleed the system thanks"
SOURCE: It Started about 6 months
REPLACE UPPER RADIATOR HOSE IT IS TOO SOFT WORN OUT CAUSE HOSE TO CLASP.I WOULD REMOVE THERMOSTAT FLUSH ENGINE BLOCK AND RADIATOR COOLANT SYSTEM NEED FLUSHING OUT.
Solved: It was a freeze plug, paid 100 dollar to reach out to the freeze plug underneath the engine , freeze plug was 2.99 , now my car is fine n happy :)
