Did you ever figure out the problem? I have a Pearl CS60 also and the red light blinks constantly and the pump won't turn on.Did you ever figure out the problem? I have a Pearl CS60 also and the red light blinks constantly and the pump won't turn on.
You can't post conmments that contain an email address.
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
There are messages on the voicemail system provided by your telephone company. This records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
If the red or others blink look to see if they are blinking a specific number of times--like red one blinking 3 times, pause and repeating--this is a error code and may indicate what problem in set is.
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
it blinks 5-6 times
Had the pump tested, they said it was fine. Could the on/off switch be bad?
