Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
There is some suction but not nearly what it should be. Bag is new, and for a test I removed the filter and that only made minimal improvement.
I used to be a service manager for Electrolux. It sounds like possibly a clogged fan or hose. Take the hose off and check the amount of vacuum at the opening of the cleaner. If it has more suction without the hose, hold the hose in place backwards to try to **** the junk out of it. If the hose was damaged inside, it may be necessary to have it cleaned out with a very small hook. Make sure you have the filter & bag in place. They are needed to make a complete seal in the vacuum system. Make sure the suction control door on the hose (near the handle) if shut. This is normally only opened to vacuum curtains and loose hanging draperies.
Posted on Jan 01, 2009
What you can do is
check that the pipes are not blocked
this happens alot
to check if it is your vacume or pipes
unclip the pipes and put your hand to where the pipe conects with the unit on
if there is still no suction look to see if there is a speed switch and turn this up if it is low
if this dose not work you might need a new motor
hope this helps ;-)
ricko
Posted on Dec 29, 2008
It could be the motor
Oct 19, 2015 | Kenmore Vacuums
Mar 21, 2015 | Sebo Felix 4 Premium 9824AM
Jul 25, 2010 | Vacuums
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Mar 21, 2010 | Bissell 3522 PowerForce Bagged Upright...
Mar 19, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
Nov 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Jul 04, 2008 | Panasonic Vacuums
Feb 24, 2008 | Kenmore 28075 Bagged Canister Vacuum
172 people viewed this question
