When I make a phone I cannot hear the phone ringing and after the phone connects I cannot hear the person I called. They can hear me. I removed and replaced the battery and also Reset the settings back to the defaults. The phone rings when someone calls me, but I cannot hear them.
my hunch is the ear speaker of the phone is faulty and needs to be replaced, have you tried calling using either the handsfree/ Loudspeaker or the headset if you can hear with one of these then its surely the earspeaker to be faulty
hope this helps, cheers.
Testimonial: "Duh. . . Should have thought of that. Seems to be a faulty ear speaker because I can hear with both the loudspeaker and the hands free. THANKS!"
SOURCE: Can make calls, but cannot hear when it rings or when it picks up
you have answered the query correctly go ahead and change the ear piece speaker thats faulty
SOURCE: i cant hear anyone nor can they hear me during a phone call
Once water gets inside the phone there is not much you can do about it. If you want you can try what I have done for my daughter many times with good results. Remove the battery, this will help a great deal. Just having the phone powered up is not a good thing while it is wet. After removing the battery allow it to air dry, you can use a hair dryer to speed things up, but be careful not to get the phone too hot. I hold it in my hand and that keeps me from getting it to hot.
Leave the battery out for as long as you can, days would be better than hours. Then put the battery back in and see if the moisture is out of the phone. If this works you are good to go, if not then your phone may be beyond help because of the water.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for you support
