ViewSonic E70f  17" CRT Monitor
Problem for ViewSonic E70f (Beige) 17" CRT Monitor
Horizontal output transistor keeps failing
By joebert on May 15, 2007
I have this 17" viewsonic and finally it fails, i check inside and found the horizontal output transistor BU4522AX fails, i've replaced it three times but keeps failing. dc voltages seems to be normal. please help me.
Comments:
May 15, 2007
- i hav fixed the two, output transisitor and a shorted switch mosfet but there is still no picture that seems like the switching circuit is not working, i never change the IC yet. the LED changes from orange to green but there was no high voltage or horizontal out. i out of my wit right now on this. You may help me.
Same Problem
Aug 25, 2008
-   hot keeps failing-   wildtaurus
Jun 07, 2008
-   horizontal out transistor keeps failing on my 17" monitor-   Guest
May 29, 2008
-   Dear Sir,
No display problem. I have VIEWSONIC VCDTS2183-1P (Optiquest Q41) model CRT monitor. BU2508 was short i replaced it with new one. After replacing then also there is no display on monitor. Please help me to solve this problem.-   prashantmane
Best Solution
posted on May 16, 2007
Very Helpful)
juandelacruz
Rank: Wiz
Rating: 83%, 255 votes
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor.
The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary.
The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 28, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Replaced your horizontal output transistor D5072 and this solve your problem.
Solution #3
posted on May 20, 2007
Helpful)
Johannah
Rank: Wiz
Rating: 80%, 51 votes
What do u mean by LOT ( EHT ), in this problem, the main 200v supply intended for the horizontal output transistor wud passed thru a MOSFET, The gate was connected to the output of an IC that determines the presence of signal from a computer. The MOSFET would reduce this voltage to 165v for the hor transistor. now the presence of signal from computer would change the LED from orange to green, but the 200V did not passed to the hor transistor, the MOSFET was not turned on. One thing i've noticed was if i remove the hor out transistor, the MOSFET would turn on. This MOSFET will reduce the 200v to 165v so i could not try shorting it when the hor out transistor is soldered. i've already change shorted 0.22mf capacitor in the flyback transformer that i thought was the cause and the 2.2uf/50v capacitor blown before. please explain to me what u mean LOT.
Was this helpful?
Yes
No
Solution #4
posted on Mar 10, 2009
Not Rated)
gary_tone200
Rank: Apprentice
Rating: 0%, 0 votes
my tv is daewo 29 inch. help me what kind of horizontal out we are to replace cause its always damage in minutes.tyvm
Was this helpful?
Yes
No
Solution #5
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
replace the LOT (eht) transformer and than put the new horizantal transistor than switch on and monitor will b displays ok
Popular Solutions for ViewSonic E70f 17" CRT
Questions and Unsolved Problems for ViewSonic E70f 17" CRT
Do you recommend ViewSonic E70f (Beige) 17" CRT Monitor?
Answer
Answer
I unlocked OSD Locked of CRT View Sonic Colour Monitor desk top ( Block) by pressing. while restart... (More)
Answer
i cant install my monitor,its a view panel vg151, it only says ¨testing¨and doesnt... (More)
Answer
I have a view sonic vp2130b a square about 3'4 of an inch has started in the center. It stays no... (More)
Answer
continuously displaying ultrabite3x: Graphics/game window
Answer
my problam with view sonic monitir 17"inches crt ...every time it shows memory recall ok? hw 2... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ViewSonic E70f 17" CRT...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
