Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis f-1 error code about every 4th washing
Kenmore elite oasis 27052 won't start every 4th washing till you wait 5 minutes to restart then works fine what needs to be done
  • wes10s Apr 04, 2009
    This problem is getting progessivly worse - needs to be reset 4 or 5 times when it occurs, then runs through the rest of the cycle just fine. This always seems to happen during a rinse cycle, with 19 minutes or so left in the complete operation
  • Bobby pipkin
    Bobby pipkin Oct 21, 2013
    spin to
  • 91 Answers
Main control board need replacing
Posted on Jan 04, 2009
Kenmore elite oasis top load error code Ld
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
F 1 error comes up alot and I have to restart the load 2-3 times
Hello
Fi error code means controller senses something wrong with pressure switch or water level signal
Check water level /pressure switch before replacing controller.Switch could have kinked /clogged hose
Or switch needs to be replaced.
Aug 22, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Code F
These units have several very common error codes. the most common being error code F1. Oasis washer repair is simple. The link below has a video that explains how to replace the main control board on a Oasis washing machine.
Oasis Washing Machine Repair Video
http://www.appliancerepairlesson.com/
Mar 15, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
KENMORE ELITE OASIS- comes up with a code: DL ( REPEATEDLY - CHECKED THE LOAD- BECAUSE IT STOPS- WON'T RESTART.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error
yep electronis control board in the console is bad.
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
764 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
