Question about Maytag PYE2300AY Electric Dryer
Maytag performa model#pyg2300aww takes four cycles to dry
Takes about four cycles to dry load but is warm
  • 148 Answers
How long is dryer vent run ? does it go up or out to the side ? Sounds like the dryer vent is clogged. A long run on your vent will also cause this problem with a small amount of lint. Try cleaning out your lint screen on the dryer vent they can get pretty caked up with lint. If you have a long dryer vent run post back the length and direction and I will get you the maximum length for your specific run. You may need a booster fan if it is excessively long or straight up as through the roof.
Posted on Dec 31, 2008
My dryer takes hours to dry one load of clothes. Cleaned all lint from it. It's warm, not hot. Flame is on.
you need to either dismantle the venting pipe ductwork inside the dryer and get inside the duct and loosen all dried on lint which is holding moisture in,otherwise the cycling switch for the flame is cutting out tooooo sooooon and your not drying the load properly per selected load setting
Mar 14, 2010 | Maytag Neptune MDG9700A Gas Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
Dryer runs and has heat, but takes 3-4 cycles to dry
inspect your dryer vent if it is clogged or has standing water in it, that will cause your problem
May 12, 2009 | Dryers
My maytag performa gas dryer model # pyg2300aww gets warm but takes four cycles to dry.
clean your dryer vent going from the back of the dryer to outside also run a lint brush down where you put the lint screen in if this does not help replace your coils
Dec 29, 2008 | Dryers
It takes several auto cycles on regular heat to dry a load of laundry when I think it should only take one. What's wrong?
first, check your exhaust, you have to make sure there is no buildup at all inside it. this is the most common problem to cause this. if lint gets backed up, there is a sensor that shuts down the heating element after only a few seconds. hope this helps
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
Aug 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
279 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
