Question about FIC Samba SM-1845 (SM1845GV) Barebone
Disable onboard NIC
I don't see any way to disable the onboard NIC on the SAMBA 1845. And since I don't have a manual to go with it then I am asking you guys for some assistance. Thanks for your time.
  • 385 Answers
Onboard LAN can be disabled through the desktop board BIOS Setup Utility. The setting is located in the Advanced screen under Peripheral Configuration.
Posted on Apr 27, 2007
Samba 1845 won't boot how can I make it do so?
From what I can tell it would be HDD related. Have you test the HDD, is good? Do you have a Recovery disk of your OS? The machine has some miles on it ,right? I would start trying to load the disks (CD) that came with the machine, (I don't know your OS), If you don't have them, you can search for a windows repair disk online.
Nov 18, 2012 | Computers & Internet
NEED NIC DRIVERS
Any drivers are available on the manufacturers web site.
Use another computer and download the relevant drivers to a usb stick and install them to the NIC. (Whatever that is).
Feb 02, 2018 | FIC Samba SM-1845 (SM1845GV) Barebone
Inside my emachine desktop pc where do I find the network interface card? I need to replace it since an electrical storm destroyed it.
The NIC (network interface card) resembles a telephone jack only larger. It's where your ethernet cable goes. On some E-machines, the NIC is onboard meaning it's permanently attached to the motherboard. If this is the case, it's still possible to install a different NIC in 1 of the blank PCI slots. Remember to Disable the existing NIC in your device manager to avoid any possible conflict.
Aug 31, 2011 | E-Machines eMachines Desktop PC
Hi, excuse my poor english. How can I disable onboard video on a Lenovo M55e 9632AE2? Thanks in advance. Markus Brandl
There are two ways to disable the onboard video:
First Option:
When the machine boots up, watch for instructions such as "Press to enter setup, bios, configuration, ect." Within the BIOS setup should be an option to disable to onboard video. This can usually be found within an Integrated Chipset Features section or a Video section depending on your BIOS. Be careful though, messing with settings that you don't understand can affect your computer negatively.
Second Option:
Assuming you're disabling the onboard video because you have installed a video card, access the device manager by right-clicking "My Computer" and click Manage. Select the Device Manager on the navigation pane on the left, then expand the Display Adapters section. Right-click on your onboard graphics adapter and then click Disable and you're done!
May 25, 2011 | Lenovo ThinkCentre M55e 9632 PC Desktop
On a Gateway GT5028 - appears the ethernet card was damaged by power surge. We installed a new 10/100 NIC card but Gateway reports it has a problem. Any ideas? Do I need to disable the onboard NIC card...
No you do not need to disable the onboard Network Interface Card. I would suggest to first start by inserting the new NIC card in a dif. Spot.
If you do not have any other spots to insert it, i would double check to make sure you have the correct driver for the correct operating system that you are running, If you know the model # of your nic card i could gladly get you the correct driver. Let me know if this helps. Thanks
Jun 20, 2010 | Gateway GT5028 PC Desktop
I need the drivers for the samba 845gv
Go to manufacturers web site
There you can find all the drivers you may need
Nov 17, 2009 | FIC Samba SM-1845 (SM1845GV) Barebone
Just bought this Samba 1845 system. Upon power on receive bios rom checksum error, insert system disk. Is the battery dead, bios need to be flashed again, please help
A BIOS sum check error is usually due to a near flat BIOS battery.
Replace the BIOS battery and configure the BIOS Date & Time setting etc.
Oct 27, 2009 | FIC Samba SM-1845 (SM1845GV) Barebone
Emachine T3624 NIC Problem
Shut the computer off at the beginning of the bootup process look for the function key or keyboard button to get into the bios setup. Press that button and look in the settings to disable the onboard network adaptor.
Nov 27, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Upgrade CPU In my SAMBA SM-1845
Hi, as long as both chips are slot 478 it should work fine, you wont need to change any bios or jumpers, just open up the computer, remove the heatsink, lift the lever and remove the CPU.
Insert new processor.
you will need thermal grease at this point, you need to apply a little amount onto the cpu, and make sure the old thermal paste is removed from the heatsink and then refit the heatsink & fan.
other option is fit the new cpu and purchase a new heatsink & fan, they usually come with the thermal grease, a new heatsink will cost about £10 or themal grease by itself will cost about 2-3 pounds.
just make sure you have new thermal paste before you remove the heatsink as the processor will get damaged otherwise..
Hope this helps
John
Jul 31, 2008 | FIC Samba SM-1845 (SM1845GV) Barebone
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
FIC Samba SM-1845 (SM1845GV) Barebone Logo
1,922 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
