Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The power flickers on and off after opening or closing
The door opens then the power to the unit flickers on and off for a couple of minutes and then goes back to showing on and you can then close the door. Happens when door is opened or closed.
    Champion:
  • 244 Answers
What happens if you plug a lamp into outlet. does it stay lit.
Posted on Jan 15, 2009
I have a Craftsman model 139.53930 garage door opener that is acting up.
You need to check the manual. If manual describes anything lije that then its good, if not then it sound lije board issue with relay or capacitor
Jan 02, 2018 | Computers & Internet
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
My Daewoo FRS-2021IAL fridge/freezer control panel flickers when open/closing either door. after a power cut, turns on unlocked & difficult to set freezer temp & to lock again. Backlight stays on...
try to re insert the ribbon connector on your PCB board possible loose connection then reset your unit to unplug your unit for a few minutes the n plug on after then observe the operation.
Mar 06, 2011 | Refrigerators
Guardian garage door opener not working,when I press the remote handheld button,the light in motor unit starts flickering. untill I press one of the 4 small switches,then it stops flickering. garage door...
Is your door jammed or could the door be moved smoothly? If not then the motor might not be able to start and it flickers, try to press "+" for open or close (depends on whether the unit is going to close or open the door) once at a time and try to remote it, this will increase the open/close force and may overcome the issue.One more thing, do the photo-eye sensors give unobstructed with good indication?
Jan 20, 2011 | Kitchen Ranges
F5 error door locked
F5
- E0 Door switches do not agree (condition
exists when door switch is closed indicating an open door, and latch switch is
closed indicating a locked door) 1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    switch to control. If no damage to wires and all connectors okay, proceed to
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
    operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes.
Dec 27, 2010 | Whirlpool RBD275PD Electric Double Oven
Error code F5EO
F5
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 19, 2010 | KitchenAid KEBC107 Electric Single Oven
Craftsman 139.53673SRT1 garage door opener (1997 model) worked yesterday. Today the unit is not responding, the light does not flash, the LED blinks 5 times then stops and then starts again. Unit clicks...
Usually when this happens it is because the door is open and the trolley is jammed against the bolt just in front of the motor unit. Try loosening the chain to relieve the pressure on the trolley and then close the door. While the door is closed locate the 'up limit' control on the side of the motor unit and turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Now tighten the chain.
Mar 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener intermittently not closing
A couple things to check and do. If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit if necessary.
If the main light isn't flashing it may just be a simple adjustment. Locate the 'down force' adjustment on the rear of the motor unit near where all those white wires go. Increase this about 1/4 turn and try.
For the light you should unplug the unit and then using a small screwdriver pull out on the center contact in the light socket.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
My craftsman139.53644SRT won't close w/remote
You must make sure you followed the color coding of the wiring to the sensors. One wire is solid white and the other is white with a black stripe. Make sure the small light on each sensor is lit and not flickering. If nothing works then you must have a power problem. Make sure it is plugged in.
Jul 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
64 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
