Question about HP Pavilion dv9000z Notebook
Having a little trouble getting my mic working on an HP DV2125NR. The mic is giving me nothing but static when I test it. I have tried 3 different headsets in addition to the built in mic with no luck. I have updated my audio drivers first from HP then from windows update and still the same problem. I am running Vista Ultimate x64.
  • dwyann Jan 08, 2009
    I am experiencing the exact same problem. I have tried updating the drivers and the BIOS. The "roll back driver" option is greyed out and not available.
    Genius:
  • 1,066 Answers
Are you using the windows sound recorder? there is a known problem with sound recorder when used on a system with more than 2 gigs of ram.
Posted on Dec 29, 2008
Trouble with three SM57 having low volume unless directly on sound source
It is unlikely there is anything wrong wit the mics. The SM57 is very simple. Literally just a magnet and coil of wire. The problem that you describe is likely caused by your mixer, the presonus, etc.
Oct 29, 2012 | Shure SM57-LC Professional Microphone
AUDIO PROBLEM
First, try your mic on a different PC. If it works, then come back to this one.
This model of Compaq PC has always had a little trouble with speakers and audio in general. Try inserting the MIC's jack into the output, and see whether that works. Generally, don't go by their color coding, just plug it into a jack until you find the one that does work.
Make sure that you do not have the MIC turned off, either in the audio controls' software, or the physical MIC. You should be successful.
-a.
May 31, 2010 | HP Compaq d530 SFF PC Desktop
It will not transmit or recevie i get a little static on the weather channle but nothing on the cb i can here the mic key up when i have my other cb on but that is all.
there may be an issue with the mic. The mic is required for receive. there may be some broken wires in the cord for the receive and mic.
Try a different mic.
Mar 31, 2010 | Maxon MCB-30 40-Channels Base CB Radio
Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
Mic isnt picking up voice
IF U ARE USING ANY SOFTWARE TRY CHANGING OR USING DIFFERENT SOFTWARE.ALSO CHECK UR MIC AND CONNECTIONS IS IT WORKING CORRECTLY OR NOT.
Apr 01, 2009 | HP (153147-001) Sound Card
Many Problems with Samson G-Track or not?
Hi.  I dunno if yur using pc or mac but with a mac yu need to adjust the mic settings on the comp. For the static its probably your set up or as i said in another guys problem, the usb cable given with it is **** so try using another one from a printer or wtv to see if that makes a difference for you. Also if you are recording just through the mic i find that it seems to only work well when the input is on line and not inst/mic. Hope this can be of some help. Its a great piece of kit once you get it working well.. Goodluck
Jan 16, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Having trouble with the mic
Go to the mixer controls. Press the advanced button under the mic mixer control and turn off the mic boost. If the advanced button isn't on, go to control panel, select sound, and make sure that enable advanced features is turned on for both your sound card and your microphone device.
Aug 14, 2008 | Aiptek Pocket DV 5900 DV Digital Camcorder
Microphone and speaker problems
Do a virus scan first FREE ANTI VIRUS Try here its free http://www.kaspersky.com/kos/eng/partner... If you can not access or open IE right click in and select Properties then set the homepage to Blank! SOUND RECORDING\MIC ON USB CAMERA In Windows XP Select the proper Audio Input Device (Sound Recording) under the Audio Tab in Sounds and Audio Devices in Control panel. Usually it is name after the USB Camera. CONNECTION Check your connections on Rear part of your PC. Lime is for Sound Out usually a speaker, Pink is for Mic, Blue for Audio Input. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester.
Sep 20, 2007 | Audio Players & Recorders
Motorola Talkabout T5400
Hello, There is not compability issue, sounds like you have a mic problem because you hear the Roger Beep and that means that the transmition and Reception cicle is working if you could test an audio accesorie would be great. There is another possibility if one of the radios is out of frequency you could experiment the same symtoms.
Apr 16, 2007 | Motorola Talkabout T5400 (14 Channels)...
HP Pavilion dv9000z Notebook Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
