Question about Coby DVD-209
Not able to play color DVD
Not able to set up color
  • atelier191 Dec 29, 2008
    display in black and white
  • Pekinduck May 11, 2010
    Does it display in black and white, or do color dvd's not work at all?
    President:
  • 563 Answers
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Do you have a button on your remote marked N/P or NTSC/PAL? If you do, try pressing it to see if this brings back the color. After trying that, if it doesn't work, or you don't have a button like that on your remote, look for a button marked PSCAN. If that doesn't work, please send an email to coby@fox-international.com. Please be sure to put "Request for tech support" in the subject line of the email.
If you feel this solution doesn't deserve a goodrating, please let me know why so that I may better assist you. Ifthere is anything more I can do to help, I will!
Posted on Feb 05, 2009
When playing DVD on panasonic plasma TV, the color is black and white
Consult the owner manual for the player (and or try it on another set) as many players have settings that can cause B&W or a single color display for the image.
Dec 02, 2012 | Panasonic Viera 50" Class 1080p Full HD 3D...
Won't play in color
If set it is hooked to works ok then look in the DVD player menu (this problem is listed under DVD players) for a setting that will make picture have no color (perfect black and white image).
If no, you may have a circuit problem in the unit and unless it is an expensive and newer one---replace the entire player.
Apr 17, 2012 | Televison & Video
DVD disks just play in black and white. No color.
This is because of the audio video format issue. You select the TV type to auto (Advisable) or to the appropriate selection such as PAL or NTSC in the DVD player to get the better output with the color.
This selection you usually find in settings > Video setup> TV Type
Aug 06, 2009 | Zenith XBV443 DVD Player/VCR
No longer plays color picture
Try the settings for "pal - ntsc - cvbs" video formats, if the tv and dvd aren't set the same, then this can cause the problem(usually with distortion to picture, depending on how it's mis-matched)
Jul 05, 2009 | Coby DVD-224 DVD Player
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
DVD Player will not play in color?
I dont think so  the DVD palyer is playing the videos that means the Player is connected properly
i would suggest you to check the color settings either of the DVD player (you might find how to do this in the manual,  would be easy) else check  wheather the color setting on your tv  are not set to SCEAM on the video mode.
hope this helps otherwose  please do post back and pls dont forget to rate the solution
Nov 23, 2008 | Memorex Televison & Video
DVD - S520 Player stuck on initialize
please check you TV color system. you are not using the right color frequency. if your TV has got an auto color region select then set it to auto. otherwise, select the TV color mode until you get the right color frequency
Jun 03, 2008 | Yamaha DVD-S520 DVD Player
Go Video Playback Problem
Have you checked the NTSC/PAL setting of your DVD?
Feb 25, 2008 | Curtis DVD8017 Portable DVD Player
VCR/DVD setup for color on LCD TV
check to see you have the cables required by the tv. usually you need hdmi or dvid for hd display. digital rights management protocols have resulted in chips in playing devices that allow only the use of the referenced cables to protect content from being copied. in some sets they default to not playing in hd, but still play something.
look there first, otherwise you may have an input source mismatch. follow instructions on the dvd player first, then make sure the tv has compatible settings.
if that does not solve, you have a service issue with one or both.
good luck
mark
Dec 17, 2007 | LG 42LC2D 42 in. LCD HDTV
Original DVD plays black and white
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Aug 18, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Coby DVD-209 Logo
65 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
