Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner says its busy when trying to scan item
Everything else works great! I really need the CD to reinstall the web relase install didnt have the HP PHOTO working so weird anyone else have this issue? I love this printer hate to get a new one
Tonerman
  • 62 Answers
SOURCE: HP Officejet 7310 All-in-One Scanner problem
If the HP service cant help, then try to get a exchange, the machine usually have a warranty.
Posted on Jul 11, 2007
SOURCE: HP All-in-one will not scan
Had the exact same problem - All-in-one would not scan with the same error message. Found the solution. Go to my computer (in XP) -> Control Panel -> Printers and Other Hardware -> View Installed Printers. Look at the bottom left in the side column of the window, you'll see "Scanners and Cameras". Click that option and it will walk you through the process. It works perfectly! Good luck!!
Posted on Aug 20, 2007
Silan
  • 54 Answers
SOURCE: scanner not working
Please open HP director from Start - All programs - HP .
Click Scan document to scan.
You can scan by following steps :
For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
Waiting for you reply.
Thanks
Posted on Dec 22, 2007
rizla
  • 1463 Answers
SOURCE: how do i install hp laser jet 1018 printer
hi johnboy
you can download the driver from here hp 1018
select your windows to download .
riz.
Posted on Jun 09, 2008
  • 53 Answers
SOURCE: photo smart 2610 all in one scanner will not scan
hey i also had this type of problem. but i solved it and hope it will solve yours too.
first of all uninstall all ur hp drivers and softwares related to the hp printer. then restart your pc. now disconnect ur printer with ur computer and turn it off and again on after 15 secs.
now insert the cd which i have got with the hp printer in the cd-driver of ur pc and install the driver.
after the installation is complete, connect ur printer, but do not remove ur cd.
then start scanning, and if it will again ask for installing driver, u dont have to worry it will install it from the cd.
this would surely help u, if problem persists, please tell me.
Posted on Jan 03, 2009
Hi...I have a Kodak, 3250 3n1 printer. When I bought this printer several months ago, I loaded the cd and walked thru the exact instructions to download the scanner. Everything worked great!...I was able...
Reboot your computer as well as your scanner, also check your data cable if properly connected as well as the power cord of your scanner, else try to uninstall your printer/scanner and reinstall it again. Reboot again and try connecting again. Usually, it is not possible to use your scanner simultaneously while printing.
Jul 05, 2017 | Kodak Esp 3250 Allinone Multifunction ( ...
I have just bought a HP Photosmart plus B210 printer. I have installed it ok and it is wireless connected. everything seems ok for printing but when I try to scan to Paint shop Pro 7 or from Word 2003 it...
Hello Carol,
The first thing you want to do is check to make sure the scanner driver is installed properly and working.
If you are running Windows XP or Vista; go to Start Menu \ Control Panel \ Scanners and Cameras
NOTE: For Vista user you must select "classic view" in control panel to see scanners an cameras.
For Windows 7; go to your Start Menu, in the "search programs and files" section (found below "all programs") type in "scan". You will see a result for View Scanners and Cameras.
Now you should see the HP scanner here. If it is not here then you need to reinstall because the scanner was not installed properly. If the scanner is here, right click on it and select Properties. (For Windows 7 you do not have to right click, you will see Properties at the bottom of the window).
In the properties select "test scanner". If this test fails, the driver is not working and you should uninstall and reinstall the HP.
If this test works then the driver is properly installed. HP should have provided you with some sort of scanning software, try scanning using that. You can also try scanning using Windows Fax and scan (for windows 7), Windows Photo Gallery (Windows Vista) or the Windows Scan wizard (Windows XP).
Thanks,
Pat
Nov 07, 2010 | Office Equipment & Supplies
I uninstalled my cd for hp Officejet 5610 and then reinstalled everything from the cd. Now it will print and fax - but cannot scan.in the hp Solutions window it does not even offer me any scan options at...
The scanner driver might not be installed. try inserting the CD installer again then select the scanner driver. Restart after installation is complete.
Thanks,
dDex
Jun 29, 2010 | HP Officejet 5610 All-In-One InkJet...
I have a Photosmart 3310 that I use with a MacBook Pro. I have scanned before but all of a sudden I can't scan. I have tried restarting, reinstalling software, restarting Photoshop. Help!!!
Don't reinstall Photoshop any more, that's not necessary. Just leave PS alone.
Have you done anything, like upgraded the operating system?
Try a couple of things. We'll start with the easiest.
Try scanning directly from the "Preview" application - this works really well.
Open the application "Preview"
Go to the File menu, and then "Import from Scanner" - hopefully your scanner shows up ...
This is a great way to scan.
If your printer/scanner does not show up when you do this, you will need to (sorry to say) re-install the software for the printer. But you said you already did that!
I'm going to suggest, if you haven't already, to go to hp.com and find your printer and download the package of software for it and reinstall that way - they periodically update the software. HP printers are a bit fussy about this, so reinstalling the "latest" HP software is definitely worth trying.
Hope that helps!
For PA system troubleshooting and general assistance with conference audio, visit rexark.com
Jan 08, 2010 | HP Photosmart 3310 Printer
Using HP 5300C scanner with Windows ME for years.
Are you still on ME? Might be time to step up to XP or vista, nevertheless, try this.. works great on my XP pro and Vista with some tweaking, but straight forward with XP Pro. Good luck! Does it show up in your hardware profiles? What does it say on details when you right click the scanner? When you installed the driver, was it before your plugged in the USB? You may have to uninstall and reinstall it again, this time use the one from HP's website with any patch if applicable.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=sj664en&lc=en&cc=us&dlc=en&product=58381&os=228&lang=en
If you have successfully used it in the past, follow the install prompts and restart.. instead of using the products software, use Windows included scanning program which is much better than the proprietary one designed by HP. As long as you have the proper driver installed your system will know how to apply it.
Jan 05, 2010 | HP ScanJet 5300C Flatbed Scanner
My scanner doesn't scan, says no scan options
HI, HAVE TRIED TO UNPLUG AND PLUG IT BACK IN? THE SCANNER COMES WITH A CD INSTALL THAT CD AND WILL GO TO SET UP. THE SCANNER SHOULD WORK SOON THE SETUP IS DONE. IF YOU MISPLACE THE CD YOU CAN GO THE HP WEB SITE AND DOWNLOAD THE SCANNER SETUP SOFTWARE. HOPE THIS WILL HELP YOU.
HH
Aug 13, 2009 | HP Officejet 6310 All-In-One InkJet...
Vupoint FS-C1-VP scanner installed
i have vista home and mine worked fine until i installed a web cam and then it just gave up. But now it works great - here is what i did
unpluged both the scanner and the web cam
uninstalled everything to to w/ the scanner and the web cam.
Installed the driver from the CD and restarted my machine
Install the Photo 6 software
plug in the scanner - works like a champ.
have not reinstalled the web cam
Oct 02, 2008 | Office Equipment & Supplies
I have a HP photosmart C6180 all-in-one and I am trying to scan a picture onto the computer but every time I go to the scan menu it says Error: Sorry, scanner could not be initialized. (Scanner not found.)
I get this every now and then, usually because, during a scan, I abort for some reason--reset the computer, force-quit, whatever.  The printer driver, I think, leaves some breadcrumbs that it can't recover from when it runs again.
Anyway, I reset the printing system and install the latest HP driver.  If that doesn't work, I delete the HP folder in the Applications folder; then remove whatever files I can find in the /Library folder such as Application Support/Hewlett-Packard, Application Support/HP, any HP file in Preferences, Image Capture/TWAIN Data Sources/HPScanPro.ds.
Then reinstall the driver and things work fine.  I'm thinking this last item, the HPScanPro.ds in the TWAIN folder might be the culprit but I haven't tried just remove it alone--after I remove everything things work so I can't "try it again"...and don't want to!  =)
Anyway, I've had success with this method.  Good luck!
Jul 13, 2008 | Office Equipment & Supplies
The HP OfficeJet J5780 All In One SCANNER Problem
it means that te software for the scanner is not properly installed or corrupted,reinstalling the software will solve
thnx N
Feb 15, 2008 | HP Officejet J5780 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
188 people viewed this question
Ben Johnson
