Question about Fuji FinePix S700 Digital Camera
Zoom Error and IN icon won't go away
It looks like the camera was dropped because there's a crack right in front of the zoom switch. The zoom doesn't move like it should, smoothly, it's stiff and stays in place so I'm sure that's broken. 1. Can it be replaced? 2. The IN icon on the screen will not go away and says "images recorded to internal memory" but there is a memory card in there, with a few pictures. How do I get rid of that icon and be able to take pictures to the memory card again?
Your camera is broken, mine did the same thing.
Posted on Dec 30, 2008
I dropped my Panasonic LumixDMC-ZS19 and now when I turn it on, it cycles, but then says Zoom error and won't pop out the lens. Help! I need it!
Hi, it looks like you have damaged the zoom mechanism that's why it will not zoom out . The unit will have to be repaired best to get a quote for repair first.
Jul 16, 2016 | Panasonic Cameras
ZOOM ERROR
the spare parts won't be so much, if you try and fix it yourself, you will save a ton of money otherwise it could be around $100 to send it in and get it fixed. You can start finding the problem by opening the screws on the bottom/back of the camera and find what gears are jammed and won't zoom. or I can get you a number to call to send it in, thanks
Let me know what you want to do
Apr 04, 2008 | Olympus SP-550 UZ Digital Camera
Dropped camera leads to zoom error and blurry pictures. HELP!
Your lens was damaged and probably needs service. This could be expensive so get an estimate first to help you decide what to do.
Nov 10, 2011 | Fuji FinePix S1000FD Digital Camera
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
I dropped it and it says zoom error
Sounds like the power zoom assembly (motor, gears, etc), has jammed due to the drop. That and possible electronic problems on the controller board or possibly the zoom switch itself suffered damage in the drop also. Try working the zoom switch rapidly , back and forth a few times and see if it frees up. May be a candidate for the repair shop. Sorry for your accident.
Jul 14, 2009 | Fuji FinePix S700 Digital Camera
Zoom error
There is no easy fix, you?ll have either disassemble and get dirty, or take to an authorized repair person. This zoom error problem is usually caused due to dirt or dust in the zoom mechanism.
If you think you can handle disassembling the camera then grab a set of gentile screwdrivers and follow these instructions:
You will have to remove a few circuit boards in order to get to the zoom mechanism.
Jul 01, 2009 | Fuji FinePix S700 Digital Camera
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
ZOOM ERROR
zoom error usually comes from lens off track or bent.. definitely needs repair
Feb 10, 2008 | Olympus SP-550 UZ Digital Camera
Zoom Error
Pull the lens away from the body until it clicks and then turn it clockwise while looking at the front of the camera.
Nov 13, 2007 | Fuji FinePix A600 Digital Camera
Lens error
The lenses are mounted to cylinders and the outside of the front cylinders have pins mounted to them. The pins ride in little tracks that move the front one in and out. The cylinders rorate with a motor and gears. You could have damaged gears or the pins could be off track. Its hard to know without seeing it. There is a guy who does camera repair really cheap and he sells some of the cameras he repairs on e-bay. His name is "darntoothysam" maybe you can search his webpage or the user name on e-bay. Hes really cheap too. I think what he usualy does is just swap out parts. Hes been doing it a while and has a tone of extra stuff to swap around. You could try and fix it then send it to that guy if you cant figure it out. You have to really tearn them down far to get to the lens mechanism. Did you drop it?
Apr 06, 2006 | Casio Exilim EX-S500 Digital Camera
Fuji FinePix S700 Digital Camera Logo
73 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
