Question about Holmes Products HFH435BR Compact Heater
Can't program Holmes HFH-435BR heatlogic heater
Have a heat logic heater from Holmes and can't figure out how to program the temperature. It keeps shutting off at 62 degrees farenheit.
5 Suggested Answers
  • 1420 Answers
SOURCE: holmes bh3955 or holmes hh3690
Depending where you live, here in Vermont we take square footage and multiply by 30 for a rule-of-thumb calculation. This gives us a very conservitive Btu rating. New York City use 20 Btu per square foot and Washington D.C. use 15.
Posted on Dec 07, 2007
  • 70 Answers
SOURCE: Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Posted on Jan 20, 2009
  • 74 Answers
SOURCE: Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
Posted on Dec 13, 2009
  • 6993 Answers
SOURCE: Hello, How do I get heat
If the electric heater fan comes on when you turn on the heater, but no heat seems to be coming out, you could have a blown circuit or there is a break in the actual heater coil. Most parts can be ordered directly from the manufacturer and installed quickly and easily. Before you can order the parts you need, you will want to check the unit thoroughly to detect the source of your problem. Replacing a circuit can be easy, whereas replacing or repairing the coil can be much more complicated.
Materials Needed; Voltage regulator, Screwdriver or hex driver, Replacement coil, Replacement circuits, Replacement regulator, soldering gun and solder, Wire caps, Wire clamp and Wire stripping tool.
Step 1 - Locate the Source of the Problem
If the electric heater fan comes on, and you are not getting heat, it could be a blown circuit or resistor or a broken heater coil. You will want to open the case and start testing the circuits with the voltage regulator. Look for breaks in the electrical path, and know voltages will change between circuits that are separated by resistors. Resistors are the little white cylinders that connect to the board here and there on 2 wires. Once you have checked the circuits, also look at the coil. You want to see if there is a break in the line anywhere. These wires work as a complete circuit, and if it snaps from heating and cooling over a long period of use, the circuit will be broken and not give off heat.
Step 2 - Replace Burnt Out Circuits and Resisters
If you have determined that the circuits or resisters on your unit are the source of your problems, then simply use the soldering gun to heat the contacts and remove them. Replace them with parts that meet the voltage standard for their job. This will prevent you from having issues with short circuiting in the unit. If this was the only problem you could find, put the case back together and turn it on, checking the electric heater fan for warm air.
Step 3 - Replacing the Heater Coil
The coil is what will heat up, which builds temperature for the electric heater fan to blow into the room. Modern heaters generally have a replaceable heater coil unit that can simply be installed. Make sure you follow power down procedures before removing the coil to avoid electric shock or short circuiting. Find the electrical connections on the coil and remove them, and then dismount the coil. Install the new coil and close the case up. Be sure to reconnect everything properly before turning it on.
Step 4 - Repairing a Heater Coil
In older units, the electric heater fan is not connected to the temperature gauge. This usually means that the coil is going to be more difficult to replace, as they were not built for maintenance. To repair one of these, you will need a heat resistant metal wire clamp. It should be made of a conductive material such as steel so the current will pass through it to the connected wire. Take the 2 broken ends and clamp them tightly together to repair the broken circuit.
I hope the above was helpful....
Good luck.
Posted on Apr 02, 2011
I have a Holmes accutemp model HOH2520 TG-U. The heater operates for about 10-15 minutes and then the digital readout starts fluttering and it stops heating. The next day it does the same thing. Nice...
Hello- These heaters have been recalled.The Holmes heater company will mail you a new free heater, if u mail them back your power cord. Please check the recall website. Julie :)
Mar 02, 2011 | Holmes Products HOH2501 Oil Filled...
The Holmes Comfort Temp ceramic heater works fine on Low setting, but once it is set to High temperature the illuminated digital display fades out and the unit turns itself off. Unplugging and letting the...
These heaters were not designed to be serviced in the field. If it's not over a year old, it may still be in warranty. Contact Holmes through there website for more info.
Jan 19, 2011 | Holmes Products HCH4953-U Ceramic Compact...
I need manual for holmes heatlogic heaters
SERVICEMANUALS @ COST Manuals at free download:
Is it hekpful?
Dec 19, 2010 | Heating & Cooling
Temperature control threshold too high
I have a solution. Let me buy it!! So you can replace it with something that works. I am looking for used
Holmes Heater ModelHFH5506 only and will pay top dollars.
Nov 22, 2008 | Holmes Products Holmes HFH5506-CN Heater...
IIcant find parts for the holmes heaters. Who carries them?
I have the same problem. I mean it keeps going off prematurely. The heating area is relatively clean and there is no reason for this other than the Thermal Circuit Breaker to be going bad.
I too have fruitlessly tried to find the part. It is made by Klixon and the info about it is as follows: 1NT15L-4165 It is a manual reset bimetal temperature circuit breaker. Mine says L86 L = Limit and 86 I believe represents 86 degrees Celsius which is about 187 degrees F for us Americans.
I found the Klixon people and they told me the part was not available through them; but only through Holmes themselves. So, I of course called Holmes Customer Service.
Turns out that I had a little spat with Holmes' CS Jerky... She informed me that Holmes does not sell parts and that the heaters they build and sell are not serviceable. So, I argued that they are irresponsible with regard to the environment. What, it's supposed to go to a landfill now?
But she insisted that this was so that people didn't start fires with their heaters. And she says that she has two young girls at home and wouldn't want anyone burning down their house and killing their family. So I guess after all that has nothing to do with her keeping her job by Holmes selling me another $79 heater, huh?? lol Yeah right!!! Because the guy at corporate would not want one of their heaters to start a fire. That wouldn't be an acceptable risk to make money. (Sarcasm, in case you missed it)
On another note... It's real unfortunate that you have to take the HQH307 completely apart to clean the heating area so as to not have the heater be a fire hazard. But I'm a risk to my family by taking the thing apart and then removing the two retaining screws out and two wire leads off to replace the malfunctioning part. WTF??? Since I can't get the part I suppose I could just bypass the circuit breaker. I know that's not a good idea.
Well, bottom line is, (can ya take a guess?), that I will not be buying another Holmes Heater EVER!!! Thanks Holmes...
Answer: As far as I know you cannot get the part.
If anyone has a lead on the part please let me know here.
Thanks, LightningMan
Nov 20, 2008 | Holmes Products HQH307 Compact Heater
Jan 16, 2008 | Holmes Products HCT460-U Utility Heater
Holmes bh3955 or holmes hh3690
figure out your square foot requirements - multiply 16 X 20 to get 320 sq ft. Find a heat formula to consider windows and doors and known insulation in the walls. this will give you BTu output required to raise the inside air from 68 degrees (norm) to 72 degrees.
Dec 06, 2007 | Holmes Products BH3955-U Bionaire Utility...
Holmes Products HFH435BR Compact Heater Logo
254 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
