I have the digital picture frame set on the ''optimized'' setting to automatically compress my pictures to maximize the memory, but when I transfer my pictures the file size remains the same. This picture frame has 512Mb of space and says it will hold up to 2000 pictures. I only got a little over a hundred on there. Help! Is there a way to manually make my file sizes smaller? Or what am I doing wrong?
SOURCE: SEQUENCING PICTURES IN BUILT-IN MEMORY
The DPF-80 has now way to sequence pics. The only way for them to play in an order is add them one at a time to the frame via the computer. The files can not be batch sent, such as sending a whole folder at one time. Windows will dictate the order in which they are transfered if you do it that way. Transfer one pic at a time. Tedious, but it works
SOURCE: transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Dear remove the write protection on your disk to eliminate this message, you computer or fram memory is write protected. check the properties of those and remove if they are write protected. this is resolve your issue.
Good luck in correcting your problem.
Best regard
SOURCE: We have a Pandigital photo frame and we cannot get
The transformer was showing no volts. It was dead and had to be replaced.
