Cannot get MSN messenger to connect, I have changed the proxy settings, allowed the program within the firewall settings but still return an error code of 80072efd
  • 177 Answers
Try this web-site:
http://www.imzers.com/msn/solve/error-code-80072efd
It has diagnostics
Posted on Dec 29, 2008
  • Jackson Henney Dec 29, 2008
    Hope it was your Fixya! --P3NGYJ03
Error code 8007ee7
hi,
Possible solution
  • The most likely cause for this problem is that your firewall does not allow MSN Messenger to access the Internet. This happens often if you install a new version of Messenger. Make sure MSN Messenger is allowed access in your firewall rules.
  • This error might also be occuring because there is a proxy server enabled in MSN Messenger while you do not use one. To remove the proxy settings, click the "Tools" menu and then "Options..." at your MSN Messenger main window. Then in the options screen click "Connection" in the list to the left. Next, click the "Advanced Settings..." button. You can try and uncheck all checkboxes in this screen except the one labeled "TCP" to let MSN Messenger connect through a direct connection. If that does not work you can restore the settings again by checking the boxes you unchecked before.
Oct 04, 2010 | Microsoft Windows Live Messanger
Error code 80072ee7 gateway non in linea
Error code explanation and possible solution This error occurs when you are not connected to the internet, check your internet connection and make sure it is working properly. The most likely cause for this problem is that your firewall does not allow Messenger to access the internet. This happens often if you install a new version of Messenger. Make sure Messenger is allowed access in your firewall rules. See our article on using Messenger through a firewall application. This error might also occur if a proxy server is enabled in Messenger or Internet Explorer while you do not use one. To remove the proxy settings, click the "Tools" menu and then "Options..." at your Messenger main window. Then in the options screen click "Connection" in the list to the left. Next, click the "Advanced Settings..." button. You can try and uncheck all checkboxes in this screen except the one labeled "TCP" to let Messenger connect through a direct connection. If that does not work you can restore the settings again by checking the boxes you unchecked before.
Apr 17, 2010 | Microsoft Windows XP Home Edition
I am trying to sign on to msn messenger and i get the error code it is 80048820
Please follow steps to resolved issue
The Solutions to MSN Error Code 8004882080048820_lan.jpg Internet Explorer - Try removing the tick next to Internet Explorer 'Proxy server' settings, instead, go with the 'Automatically detect settings'.
1) Launch Internet Explorer, click Tools and then click Internet Options.
From the Internet Options dialog box, go to the Connections tab.
Click LAN Setting. Un check the Use a proxy server for your LAN (These settings will not apply to dial-up or VPN connections) checkbox. Finally positively tick: 'Automatically detect settings'.
2) Register softpub.dll.
Click Start (Button), and then click Run, type regsvr32 softpub.dll. Restart MSN Messenger. See also Error code 81000314
3) If necessary, logon as a local administrator and set the computer's clock to the correct date and time. (Check on the internet if possible.)
4) Turn off the firewall temporarily. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
NetGear problem, but also with some other routers
a) Enter IP address 192.168.0.1 in your browser's address bar.
b) Log on with ISP user name and password.
c) Enter Admin, password
d) Navigate to advanced menu, WAN set-up
e) Change MTU size to 1400
5) Try a password of no more than 8 characters.
6) If you are using IE 7.0 check the SSL Settings. Internet options advanced (Tab) scroll down to the bottom. Security section. Tick 'Use ssl 2.0'.
7) One of the simplest ways of curing MSN error 80048820 is to unplug, or restart your modem. This is particularly effective for cable modems.
8) We should have tried this solution before; check that the MSN site is 'up' 'available'. However, even if the site is down, you don't usually get error code 80048820.
8a) As a variation, of checking online, you could try phoning your local Microsoft Support office. Local area numbers available from http://support.microsoft.com.
9) Have you just installed any anti-virus software? Did the anti-virus software just make a big update? Try disabling and see if that cures the error.
10) A drastic solution is to try uninstalling MSN Messenger version 8.0 or 7.5 and install Microsoft MSN version 7.0.
Hope it can resolved issue
Thanks for using Fixya
Apr 02, 2010 | Microsoft MSN Messenger Connect Service
Solution for yahoo messenger 81003005 error
You need to tell me certain things before i proceed :-
1. Are you using Broadband or Dial Up?
2. Are you using Error message when you try to connect Y messenger?
3. What Proxy settings have you tried?
If you are unable to get Yahoo Messenger to work you might want to try another messenger. The one that I use is called Trillian. This program allows you to be connected to Yahoo, MSN, AIM, & ICQ at the same time, PLUS you have multiple profiles connected to each messenger at the same time. It's a great program that is very flexable. The only reason I'm recommending this because I have also had problems in the past with Y!M and I have found that Trillian seems to always work.
http://www.ceruleanstudios.com/learn/
http://www.download.com/Trillian/3000-2150-10047473.html?part=dl-trillian&subj=dl&tag=button
Now,
Also try to Connect Y M After Turning OFF Anti-Virus and Firewall. This has been an issue with Norton and Zonealarm.
Let me know, once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Office Equipment & Supplies
Login error 81003004fo yahoo
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
When I try to sign into Yahoo Messenger 9.0 I get this error message "Messenger encountered a connection problem. Please check the network connection and then click try again. (81003004)" I've changed my...
Error code 80072ee7
Source
Please rate this solution.
Sep 20, 2008 | Computers & Internet
Error code 80048820
MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
Aug 12, 2008 | Computers & Internet
Msn LIve Messenger Contacts Cam
First of all go with right click to msn live msn and check this pics if those options look like in this pics:
http://img509.imageshack.us/my.php?image=11677175me8.jpg
The second one it can be proxy problem or ur company have a problem with msn port ( witch are port 21 )!
Dec 07, 2007 | Microsoft Office Outlook 2003 for PC
Yahoo messenger,msn messenger
you will need to log onto a user with administrative properties then get into the firewall that is blocking access to these programs from the internet and allow them full access.
Sep 09, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
