The memory battery in the unit is bad. I need to replace it
SOURCE: 2008 update for street pilot i3
When you say you are clicking on the map, are you just using your mouse pointer to click or have you actually selected the Map Select tool at the top of your Mapsource screen?
SOURCE: HOW DO YOU OPEN A
Pry off the face by gently lifting up just under the Garmin lettering. Undo the 4 face screws. gently pull the unit apart. Keep note of how the antenna goes back into place as it will follow the face forward. There is a shield with two screws holding the battery in place. The plug connected to the battery also houses the speakers so you will need to splice the new battery in.
SOURCE: Garmin Street Pilot III map source data card not accessible
Garmin has issues with the newer (ROHS Compliant) cards, so If you recently bought this card get a replacement from garmin.
I had these issues too with a 256 MB, garmin replace the card with 2 128MB cards, worked fine after that.
SOURCE: update 2009 for Street Pilot c330
2009 upgrade data is too large for garmin 330 must have sd card
