Question about Sony ACID Loops - Ugly Remnants: Volume One Volume License for PC (855309750763)
I am not able to record the tracks in acid pro 7.
I have remixed an already existing song in my pc using acid pro 7 and saved it.
but i cant open it using any other software like media player or something.
i want to record it in some other format like mp3 or something what should i do?
OK here's another one for you. I recorded a song in AcidPro4. Downloaded acidpro7and opened the same file in AcidPro7. Everything worked great for 2 days. Remixed it all until I got it just the way I wanted it. I was going to render it but I wanted to listen to it a couple of more times on a different set of peakers, But for some reason, some of the loops (not all of them mind you, just the most important ones of course) sound completely muffled. Like they are covered in a blanket. I think it has something to do with the master Bus but I don't know what I changed. Any ideas?
nxs
Posted on Aug 14, 2010
Man oh man.. have i been fighting with this problem !!!!!!!!
but guess what---- i have the answer!
so heres what the problem is believe it or not.. your antivirus program.. especially kaspersky!!
what is happening is either the program is trying to scan as you record.. or just simply is deleting the file... either way you end up with a blank record box.. and get errors when you try to open the audio files you just recorded..
so the fix is very simple!!!
tell you anitivirus program to give full permisions to acid and not to monitor acids activity
there you have it..
www.myspace.com/jphat now visit my myspace.. lol
Posted on Mar 13, 2009
4 Suggested Answers
  • 79 Answers
SOURCE: how to get serial number
Good effort.. you wont get cracks or serials here. If you have bought a serial, then just email Sony and it will be resent to you.
Posted on Jan 25, 2009
tbarratt
  • 96 Answers
SOURCE: i can't hear myself when recording on sony acid 7
this is a sound card configuration issue. many new pcs and laptop have the sound card configuration in the registry. many previously available functions are either turned off/disabled or just not configured.
its a slightly different solutuion between vista and XP, the screen look different.
1st open the control panel and select the sound & devices ICON.
this opens a view of tabs for the sound card.
under playback...on XP you need to select the mic or line is as an available monitor.
under playback in vista, the default playback device will be displayed. a right click on the tab area provides an option to view disabled devices.
again under vista if you double click on the playback device itself, a new set of tab views appears.
this new set may support a check box for "RecordMonitor" or it may have a tab for Input Monitor.
in either case set the input monitor on so you can hear your input while recording in Acid.
If these options are not available on your screen, then the solution will be more complicated.
You wioll need some registry expertise. rather than that thoiu, try to get the latest sound card driver, which may have the devices configured.
if not then i would need more detailed information on your hardware, sound card, driver version and operating system to help you any further.
under xp and vista you can find the registry entries you are looking for by searching for one that is more frequently there.
You could look for EnableRecMonitor or MasterVolume etc.
the other registry entries found there are fairly easy to follow to set them the way you want them to be. In some cases you may have to add the necessary registry entries, but as I said that's not that intuitive...
Posted on Feb 06, 2010
SOURCE: Help! Problem on Sony Acid 7- Track FX button not working?
ALL YOU HAVE TO DO IS GO TO THE TOUTORIAL TELL THE COMP YOU WANT TO KNOW HOW TO ADD AUDIO EFFECTS IT WILL TELL YOU THAT THE WINDOW IT WANTS TO SHOW YOU IS OFFSCREEN AND WILL ASK IF YOU WANT TO MOVE IT BACK CLICK AND PROBLEM SOLVED
Posted on Apr 17, 2010
I recorded about an hour of music from records. set cd track markers. wondering how to track the project so each song is a different track, when recorded to a cd. right now it's one long track.
Hi rudempis,
I not familiar with Sony's ACID Music Studio, but think it should have some of the same standard features other music studios have.
You should be able to load the long track that you have and see the graphic representation of the music. Slowly scroll to the right until you see an almost flat line, this will be the pause between songs. Once you find the pause, cut out that section and save it as an individual song. Do this with each song. When your done you should be able to burn all the songs to CD with no problems.
Hope this helps
Dec 22, 2010 | Sony ACID Music Studio 6.0 (ASAC6000)
I have a Fostex DMT-8vl 8 track digital recorder. Can I dump the tracks to Acid Music Studio 7 or Acid Pro 7 to save what I recorded in the Fostex 8 track, and will it go into seperate tracks? Thanks...
You can copy. You cannot just dump the file data. Unless you have an audio interface with multiple inputs, you can only copy 2 tracks at a time. Also, to sync the timing you'll need a midi port on the computer. Then you make the computer the "master" and the Fostex a "slave" device.
Jul 21, 2010 | Sony ACID Music Studio 7
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
Recording second track
have you tried pressing the record button on the first track arm to stop it recording?
Jul 04, 2009 | Sony Acid Music Studio 7 Full Version for...
Can not record audio anymore
Does it create a track but there is nothing in it? Turn off your anti-virus software when you record, thats how I got mine to work. Kaspersky anti-virus was making it trip offline.
Apr 27, 2009 | Sony ACID Pro 5 for PC
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
Timing problem!! help needed badly!
Your solution is to delay or speed up the sound that your running thru to your computer. The reason why they put user recording latency under the options then preferences then audio settings is not because this never happens or isn't know about. If your sound is too late in the track you have to re-record the track with a higher number try about 125-160. A hint is to play some notes to the beat, check to see that you are in time, then record what you are planning to record.
Jan 11, 2009 | Sony ACID Pro 5 for PC
Acid Pro 5
http://www.custcenter.com/cgi-bin/sonypictures.cfg/php/enduser/std_alp.php?p_sid=ZSQmvAwi&p_lva=&p_li=&p_accessibility=0&p_page=1&p_cv=1.92&p_pv=2.272&p_prods=7%2C272&p_cats=92&p_hidden_prods=&prod_lvl1=7&prod_lvl2=272&cat_lvl1=92&cat_lvl2=0&p_search_text=plays+track+on+track+2&p_new_search=1&p_search_type=answers.search_nl This is the Sony site choose Acid 5 and they have volumes of info. Hope that helps. Good Luck Tim
Mar 14, 2007 | Sony ACID Pro 5 for PC
Sony ACID Loops - Ugly Remnants: Volume One Volume License for PC (855309750763) Logo
441 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
