I need a manual for Kustom amplifier model K200B-5
    President:
  • 2,692 Answers
Base? Keyboard? Other?  Her is their website but I don't see any place to download from.
http://www.kustom.com/
Posted on Dec 29, 2008
Kustom KPM7250T mixer made a loud popping noise and lost sound to speakers during gig, but front power lights stayed on. Accessible fuse good. have it at dealer to see if can be repaired but he needs...
Pilot lights mean very little. Either a filter capacitor failed or other part(s) failed. Needs to go to the repair shop. The damage MAY be visible or require test equipment to diagnose.
Aug 11, 2011 | Kustom KPM7250T PA Amplifier/Mixer
My Kustom HV100 amplifier turns on but takes forever to make sound. When it finally works it stays on the rest of the night. How do I fix this?
if you have replaced the preamp tube than try looking at the capictor. i had just bought one and i thought the tube was out turned out i was worng
Jun 07, 2011 | Kustom High Voltage Hybrid HV100 Guitar...
Hi! I need two input/output plates for my Kustom floor monitors (KSC10ML). By input/output plate, I mean the unit that has the volume knob plus the two input/ output jacks that is screwed ino the side...
The KSC10ML has NO volume control... only two 1/4 inch jacks. To get a matching "jack cup" you will probably have to go to Kustom. I have searched for the item on the web and only jack cups that seem to come up are for Marshall or ones that use binding posts. I found one blank one but it is 5 by 7 inches... too big for that Kustom cabinet. In a pinch if you don't need it to be recessed, cut metal or ABS plastic plates and drill for two jacks.
Apr 16, 2011 | Kustom KSC10ML PA Monitor
I have a Kustom HV 100 hybrid tube amp. When I power it up, It will play normal for about 5 seconds and then the volume drops off. The preamp tube is only about 2 months old and this amp only gets played...
After the volume drops off, let the unit sit idle for a minute and then try it again. If the volume has restored for another brief period, suspect the filter caps are weak and voltage drops when you start driving the unit. In any case you need to have it serviced. Unless you can see the heater in a tube going out with vibration this may not be a DIY repair. If you see purple glow in a tube, replace it.
Apr 04, 2011 | Kustom Double Barrel 30-watt 2x12 Hybrid...
I have a Kustom KPM 4100 amp head that's cutting out. It works OK for 5-10 mins then crak snap crakle then nothing. After a cooling off period I can repeat the process. I have pulled the power amp and...
Have you tried connecting a single speaker to each output and cutting the volume down to see if you have a load or impedance problem? The amp may be perfectly fine except it's trying to play to a 2 ohm or less load :-)
Carl
Mar 16, 2011 | Kustom KPM4100 PA Amplifier/Mixer
I have my first ever electric guitar with a kustom dart 10 amp. I understand that the amp has to be plugged in to the mains through a power cord, but the kustom dart 10 brings none. Is this normal.?
No, there is a cord. OFTEN the cord is buried in cavities in the plastic foam or in cavities in cardboard like spacers in the original box. For some small amps the cord is permanently attached and is coiled up in cavity behind the speaker.
Jan 06, 2011 | Kustom Dart10FXA 10W Guitar Combo...
I NEED THE SCHEMATICS FOR A KUSTOM AMPLIFIER MODEL 4-15C SO WE CAN REPAIR IT, THANK YOU
Here is a link that might help:http://www.vintagekustom.com/FUDforum2/index.php?t=i&cat=2&rid=0&S=c04218e7e0f8ac8bb52d5b4ecde8a9d3 Also try here:http://www.stereomanuals.com/man/rep/kustom/index.htm Scroll down and be advised you will have to pay for it but at least it will be legible. This forum may or may not be of assistance:http://music-electronics-forum.com/t19128/ You might try here:http://www.kustom.com/MessageCenterDetail.aspx?ContentID=1325 Someone there might know someone who has one.
Nov 08, 2010 | Epiphone Blues Custom 30watt 2x12 Combo...
Fix for overheated Kustom KPM 7250 PA amp
You can start by trying a new fuse, use the correct fuse for your amp. If the fuse is blown, you can look at it and see the middle is burnt connecting the two sides.
Jan 16, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
195 people viewed this question
 Grubhead
Grubhead
