Removing old lock cylinder
These older vehicles had a tumbler release pin which needs to be pushed in while key tumbler assy is turned counterclockwise. Look for a small hole in the column, usualy located undernieth where the lock assy is. Insert something small such as a paper clip into the homle after turning the tumbler to the acsesorry position( backwards). push in the paper clip and rotate the lock assy backwards at the same time to release the tumber from the lock assy. and pull the tumbler out.
SOURCE: ignition lock cylinder
take the registration or title to your local dealer and have a key made from the VIN
SOURCE: how do you replace a ignigtion lock cylinder on a 1998 dodge
REMOVAL:
NOTE: The Supplemental Inflatable Restraint (SIR) system must be disarmed before removing any components in the area of the air bag system. Failure to do so may cause accidental deployment of the air bag, resulting in unnecessary SIR system repairs and/or personal injury.
Disconnect and isolate the negative battery cable from the battery.
Allow the SIR system capacitor to discharge for at least 2 minutes, before performing any removal procedures. The air bag system is now disabled.
Remove the key cylinder (ignition lock).
Using a No. 10 Torx® tamper proof bit, remove the ignition switch mounting screw. Depress the ignition switch retaining tab and carefully pry the ignition switch from the steering column.
Disconnect the electrical connectors from the ignition switch and remove the switch from the vehicle.
INSTALLATION:
Be sure the ignition switch is in the RUN position and the actuator shaft in the ignition lock housing is in the RUN position.
Reconnect the electrical connectors to the ignition switch.
Carefully install the ignition switch, making sure the ignition switch snaps over the retaining tabs.
Install and tighten the ignition switch mounting screw.
Install the key cylinder (ignition lock). Complete the installation by reversing the removal procedures.
Reconnect the negative battery cable.
Check switch operation.
Good Luck and hope this helps
SOURCE: Want to remove the ignition lock cylinder since a broken key is stuck inside.
get a phillipshead un do about 4 screws from underneath plastic cover which hides steering colume. remove cover you will see white plug on the left hand side of ignition barrel disconect.then right hand side there will be acable disconect.now get a small chissel and anti clockwise tap bolts which have no heads on them that are on top of steering colume when they are alittle bit lose use plyers its easier pull bolts out clamp will then come of and then you can pull whole ignition of. now there is 2 brass pins which hold barrel in ignition up near the key end remove and barrel will come out but it might be easier to take whole ignition to locksmith and get them to do it and get new key for around 30 bucks i did a mates about couple months ago seeya orangepeel.
SOURCE: i need to take out old ignition lock cylinder
This is what the tech manual says.....
Ignition Lock/Switch
REMOVAL & INSTALLATION
Some models covered by this manual may be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Section 6.
Fig. Fig. 2: Removing the ignition buzzer
Fig. Fig. 3: Ignition key lamp
Fig. Fig. 4: Lock lever plate removal
Fig. Fig. 5: Depress the lock plate which will expose the lock cylinder release hole
Fig. Fig. 6: Lock levers and spring assembly installed
