Question about Garmin StreetPilot C330 GPS Receiver
Loss of Somes States and Cities
I have updated my C330 Street Pilot. I just set off on a long trip from Canada to Arizona. Arizona has disappeared! When I try to type in Kansas it suddenly brings up Kentucky as the only state starting with a "K". Likewise when trying to type in Arizona the only states that come up are Alaska and Arkansas. Although I was able to bring up South Dakota it will not bring up the state capital of Pierre SD. I managed to find Phoenix by the old fashioned way of reading and memorizing a map from the nearest 7-11, always reliable and no stress. Had to get to the Phoenix Airport tonight. When selecting the "Airport" prompt it brings up airports 500 miles away, although I am sitting at the Phoenix Sky Harbour Airport. Should I throw this thing in the garbage?
  • lockheed10ap Jan 04, 2009
    I followed the instructions to perform a master reset. The reset was accomplished but it did not change anything. I tried to reload maps from the map updater. A message came up saying that the required memory for storing maps is missing. Now what?
  • alharmon Mar 04, 2009
    I updated c330 and now the unit gives the wrong directions on occasion. It has taken me miles out of the way and not used the most direct streets/roads. It worked better before the online updates.
You can perform a master reset to get it functioning again. Just following these steps:
  1. With the device powered off press the 'Bottom Right' hand corner of the 'Touchscreen'
  2. While pressing down on the screen power the unit ON and continue pressing the screen until a message says 'Do You Really Want To Erase All User Data'.
  3. Tap 'Yes' and go through the set up again.
  4. Please allow the unit sit standing still outside for 15-45 minutes
  5. Allow the unit to acquire satellites before searching again
Posted on Jan 01, 2009
Is there any update for the sanyo nvm 4370
http://us.sanyo.com/Navigation-Systems/Easy-Street-NVM-4370-Portable-Navigation
Pre-Installed Maps: Set up of the Easy Street Navigation System is simple because there's no software to download. Maps are pre-loaded and ready to go. Map data covers the US, including Alaska and Hawaii, Canada and Puerto Rico.
SANYO NVM-4370 Map Update DVD North America 2009-2010: Get accurate directions to wherever you travel including new roads, new sub-divisions, and current addresses. New and expanded coverage in over 159 cities, counties and metropolitan areas across the continental United States and Canada including Alaska, Hawaii, Puerto Rico and the U.S. Virgin Islands. You can confidently drive through unfamiliar or recently changed areas. This latest edition features over 6.18 million miles of navigable roads and an updated list of over 7.57 million Points of Interest to help you find the way to where you want to go quickly and efficiently.
Sep 17, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Garmin street pilot c330 goes on and then goes off
Try to charge the unit for 4 hrs by using a wall adapter and then try power on it again and if still the same after you full charge the unit try to contact the manufacturer check if there is a latest firmware update for the unit.
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
Asking to spell state
instead maybe click all states instead of spell states
May 13, 2009 | Garmin StreetPilot C330 GPS Receiver
How do I change the battery in a Garmin Street Pilot C330
Sep 06, 2008 | Garmin StreetPilot C330 GPS Receiver
Update 2009 for Street Pilot c330
2009 upgrade data is too large for garmin 330 must have sd card
Jun 08, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c330 instruction manuel
The instruction manual is available to download from Garmin's website, www.garmin.com. Click on the StreetPilot C330, then go to updates and downloads. You should find the manual there.
Mar 05, 2008 | Garmin StreetPilot C330 GPS Receiver
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Cracked screen on Garmin street pilot 330
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
Jan 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
162 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
