HP DV6000 doesn't power On,does any1 have this problem & answer?
My laptop HP DV6000 was working fine over the weekend when On tuesday morning it was off, still connected to the main power / no battery attched and would not power or turn on? what can I do..
  • 32,281 Answers
Check the power adapter with a multimeter to see if there is voltage (power) at the connector which plugs into the laptop. The voltage should be approx. or slightly above the voltage as per the label on the power adapter. If there is no voltage you need a new adapter.
If the power adapter is OK then the problem could be faulty RAM (memory) or the RAM is not making proper electrical connection with the motherboard. Reseat the RAM, remove it and insert it a few times, then reboot your laptop, if it doesn't boot then you most likely have faulty RAM. Take it out and insert it into another laptop to test it, or take it to your friendly computer shop so they can test it for you, then you will know if you will need to buy new RAM.
Posted on Dec 29, 2008
  • 45 Answers
Make sure that your power connector is correctly plugged in and nothing got unplugged from the outlet to the computer, most have a little light to let you know it is getting and/or transmitting power to you laptop. If you don't have a light or it isn't on try and replace it. If that does not solve your problem something have gone wrong with your computer that will need to be professionally checked out.
Is Tuesday 17th April 2017 a bank holiday, i get paid tuesday 17 will my money go in early do to bank holidays
Tuesday is not a bank holiday, only Friday and Monday are. If you usually get paid on Tuesday then you should still get paid on Tuesday as usual unless your place of work had notified you otherwise.
Apr 16, 2017 | The Computers & Internet
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
My cap lock works, but the led light doesn't work on my HP dv6000 laptop.
Does your number light work when you toglle the number key?
Mar 24, 2012 | HP Computers & Internet
My HP DV6000 beeps 4 times and I end up with a black screen and the power button Flashing
Most likely a memory problem. If you have more than one stick of memory, remove one and try it.
If that doesn't work, remove the other one and replace the one you took out.
Nov 01, 2011 | HP Pavilion dv6000z Notebook
I have a hp pavalion dv6000. It is not coming on.
there is a motherboard issue with this model. hp did offer a free repair on the motherboard.If you still have warranty, then you will need to contact hp to get your laptop motherboard repaired. they also offered an extended warranty due to this problem, you will really need to contact them ASAP so that you don't loose out, cause the motherboard replacement cost is around $600USD.
Sep 25, 2009 | HP Pavilion dv6000z Notebook
DV6000 GT375EA#ABU Only powers on from its battery
I have had the same issues with my HP dv6208 laptop. I ended up sending my laptop in at their expense to get it fixed. My suggestion to you is to go to the HP support website and chat or call them. The dv6000 series laptops had several issues with the MB and wireless card. they should replace the failed part for free even if the laptop is past its regular warranty. HP extended the warranties on several of these laptops in this product line because of the failures. You have to tell them the serial number, product number and model and they tell you wether it is covered or not. Otherwise I am pretty sure you are looking at a new motherboard for your laptop. Hope this helps...
May 12, 2009 | Computers & Internet
HP DV6000 Does not power on?? Can anyone help?
Check the power adapter with a multimeter, it could be faulty and therefore not charging the battery and the battery is flat. There would be a LED that indicates the laptop is charging when connected to the mains power.
This fault could be caused by faulty RAM (module) or it is not making proper electrical connection. Reseat the memory module a few times, if it still does not work then you possibly have faulty RAM (memory).
Dec 27, 2008 | Computers & Internet
AUTO SHUT OFF HP DV6000
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
Oct 02, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
