Question about Sony FD Trinitron WEGA KV-34HS510 34" TV
No picture after using dvd player
I was watching cable TV & decided to use the DVD player. After I turned on the DVD player, the TV (tube) went out and would not turn back on again. Tech Support said it was probably the A board, C board or the "1 K video patch." It would be $250 to come out and look at the TV. Can I diagnose & fix this myself? Browser
    Genius:
  • 1,074 Answers
$250.00 is a lot of money to have some one come and check your set.but if you are not a tech you wont be able to fix it yourself it is very technical.your problem is a faulty power supply or related circuit. good luck why dont you take there?
Posted on Apr 28, 2007
How to connect dvd player to tv
    1. If so you can get yourself a component cable and connect the DVD player to the TV using those plugs. Otherwise, you will need to get an RCA to HDMI converter.Nov 23, 2015
      Connecting old VHS/DVD Player to my Smart TV - Tom's ...
      www.tomsguide.com/.../id.../needed-connecting-vhs-dvd-player-smart.html
    Feedback
  1. 5 Easy Ways to Hook Up a DVD Player (with Pictures)
    www.wikihow.com/Hook-Up-a-DVD-Player
    wikiHowHooking up a DVD player to your TV will give you access to countless hours of movie-watching bliss, and most modern TVs and DVD players make the setup ...‎Setting Up your DVD Player - ‎Connecting with an HDMI Cable
    How to connect a standard DVD player to a TV - YouTube
    ? 2:57
    https://www.youtube.com/watch?v=8pARHjY8xoo
    Jul 5, 2011 - Uploaded by All About Home Electronics.com
    Lol I used my standard AV cables for the component, and I used an adapter to plug the audio into my speaker ...
Dec 30, 2015 | Televison & Video
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
DVD not showing a clear picture
test test test 17:05
danke bitte
do not answer test test
sorry
Jul 04, 2009 | Televison & Video
How to set the telelvision to use a dvd,
On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
Aug 04, 2008 | Philips Magnavox 27MS343S 27" TV
No picture
Hey motherann,
If your TV has only been having problems displaying a picture when using the DVD player (and normal TV stations are unaffected), you may only need to check the connections between your TV and DVD player to resolve the issue.
Most DVD players will connect to a TV using component video cables, an HDMI cable, a composite video cable, or an S-Video cable. HDMI and S-Video ports generally have a unique enough shape that the cables used to make those connections cannot be used anywhere else, but the same unfortunately does not apply to component and composite cables. Component and composite video cables share a similar shape, and can often be confused if the identifying marks on the cable itself, TV or DVD player have been removed. Composite video cables are traditionally a single connection that transmits the entire video signal from the DVD player to the TV, while component cables are a series of three cables that each transmit a portion of the same image.
The first thing I would suggest checking is that each cable is correctly connected to both the DVD player and your TV. Make sure that the cable(s) connected to your DVD player is plugged into the appropriate "Video Out" port, and attached to the TV at the corresponding "Video In" port. These ports should be labeled on both the TV and DVD player for easy identification, regardless of where the connections are located. Additionally, many manufacturers will even color-code both the connection ports and the cables themselves, to ensure that the right cable is used at any given time.
In the event that everything has been set up correctly but the TV still does not pick up a video signal from the DVD player, there could be a number of other potential problems: the cable being used could be defective, one of the connection ports used (on either the DVD player or TV) could be defective, or they may even be a loose connection inside the TV or DVD player.
Replacing a defective cable is generally the easist possible solution to this type of scenario, but if the problem still persists after doing so, you may wish to consult a repair technician to determine the cause of the problem.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 24, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
DVD no picture but sound ok lg v8824w
hi there, had same problem, try turning on the player then holding the stop button on the remote for five seconds.this should restore the video picture
Jan 19, 2008 | Televison & Video
Picture turns into looking like a reverse negative
Often you will get a bluish or reddish looking picture if your wires from your cable box/satellite or DVD player are inexpensive RCA type video cables. Try using a nice set of component cables or HDMI cable from your sources to your TV. If this is your setup, try this first...its the most inexpensive first option.
Dec 31, 2007 | Hitachi 36UX59B 36" TV
DVD sound but no picture...after pushing progressive scan button
desactivate the progressive scan or if u don't know how to do it, just do a reset on the dvd player.
Dec 29, 2007 | Samsung DVD-V4600 DVD Player/VCR
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Sony FD Trinitron WEGA KV-34HS510 34" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
