Question about RCA CC631 VHS-C Analog Camcorder
Need cable to connect camcorder to laptop
RCA Camcorder CC631
Camcorder only has yellow and white video cable.
My laptop has usb and I believe it has an S- video slot and it has a 1394 slot.
  • 473 Answers
SOURCE: Can I use Firewire to transfer video?
Your computer must be equipped with an IEEE 1394 (Firewire) interface and video capture software. Provided you have both of these, follow the directions below. To connect your digital camcorder to your computer using IEEE1394, follow these steps: 1. Connect the IEEE 1394 interface on your camcorder to the IEEE 1394 interface on your computer. 2. Turn on your computer. 3. Turn on your camcorder. 4. Start the video capture software on the computer. Image capture should begin provided the computer hardware and software are configured correctly. If image capture does not begin, you must consult the computer or capture card manufacturer for assistance. Note: If you don't have an IEEE 1394 interface on your computer, you can buy an IEEE 1394 pci card at your local computer store that will work with most current computers.
Posted on Sep 06, 2005
SOURCE: RCA 400x Digital Zoom Mini DV Camcorder
I've got the same problem the only option is to purchase a new cord for 102.50 that I've found.
Posted on Jun 26, 2007
SOURCE: RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
david@fullbliss.com
Posted on Oct 15, 2007
SOURCE: EZ201 Rca Small Wonder Camcorder
It isn’t your computer: this camera (although it is otherwise great) has serious interface issues with computers. Mine is driving me crazy and I am in South America, so all I can do is rely on these tech forums to try to get some clues. When I connect my camera to my computer, sometimes the computer sees it and it transfer files and edits just fine. Other times it sees and transfers, but then the software wont edit (says there is an error). Other times it sees it but the computer says it doesn’t recognize the device, and the software therefore wont run to upload the files. However, if I leave it plugged in long enough, *sometimes* like an hour later, it just all of a sudden recognizes it – but sometimes it never does, all day long. Sometimes I plug it in and it doesn’t show up on any drive at all, even if I change it from one USB port to another. There is a newer laptop here running Vista that never once has been able to see the camera, and an older one running XP that sees it every single time, but suffers a power surge because it is too old and tells me to unplug the device and reset the port and not to use it there again. When I can get my computer to recognize it, I immediately run the upgrade available on the site http://www.mysmallwonder.com/support/downloads.aspx and that usually fixes the problem for a few days – the computer can see the camera and recognize it for a few days – until it cant again! (Make sure to follow the instructions all the way through, which include disconnecting the camera from the computer and pressing the delete button on the camera after the download, and then turning the camera on again to finish the process.) The upgrade usually also fixes the software glitches (for when the computer recognizes it and I can upload videos, but not edit them, but today for example, the upgrade hasn’t fixed the glitches and I cannot edit at all. I am going to try deleting the RCA memory manager program and uploading again through the camera. One big problem I have is that I don’t have the original disk with me, so when the software goes psycho I have to download the program through the online upgrade that only will work when it interfaces with the plugged in camera – which depending on the day, may or may not be recognized by my computer, or even APPEAR on any drive. That’s where I am. Please let me know if anyone knows how to solve this.
Posted on Jul 06, 2008
SOURCE: RCA camcorder CC4352 damaged DC cable
My son has the same model camcorder so we are taking turns using the DC cable.
Posted on Sep 17, 2008
How do I make the connections from the Red - White - Yellow RCA Male plugs of the camera to a USB adapter Red - Blue - Green RCA Female to download to a computer? Stumped.
Hello, for the descriptions of the colors (red. green, and blue) of the USB video adapter, what you have is a "component video input" also called YUV in which you can only send color difference signals from a device that has the same kind of output, like a DVD player. So, you cannot plug your cam cable directly to them.
Maybe your USB adapter has another input or dongle in which the colors of the RCA jacks are the same as you have in your camcorder. Red: right Audio, Black: left Audio and Yellow: composite video.
Send me back more info of your adapter, like make and model, maybe I can see the specs and add more help in this matter.
Good luck
Dec 09, 2010 | Sharp VL-E610U Camcorder
How do I connect a camera to my pavilion n5430?
Follow these steps :
Identify the ports you have on your computer and video camera. Typically there will be a small door or flap at the rear or near the bottom that covers the ports. You computer may have ports in the front as well as the rear. You video camera may have more than one of these ports and may not have all of them.
Find the i.LINK port. i.LINK is
version of IEEE-1394 standard (aka) Firewire. It is commonly found on DV (Digital Video) varieties of camcorders. You may find the smaller 4 pin connector on your camera if it is a compact video camera. Typically the larger 6 pin variety is found on computers and larger camcorders. i.LINK transfers both video and audio. For more information click on "How i.LINK Works" in the Resources section.
Find the USB port. USB (Universal Serial Bus) is another connector like i.LINK for transferring digital video and audio. Typically a mini USB connector such as the "Mini-A" will be found on your camcorder than large flat "Type A" connector typically found on computers.
Locate the S-Video jack. The S-Video jack is a round 4 pin analog connector. S-Video is for only video transmission. You will need to connect the red and white audio RCA jacks or use a phono port to transfer the audio to your computer.
5
Find RCA Audio/Video Jacks. These round single pin ports usually are found in a set of three of different colors. Yellow is video, red is for right audio, and white is for left audio. On some Handycam's, there may be a mini-plug that is an all in one Audio/Video jack that you plug in a special cable (as seen in the photo) that connects your camera to standard yellow, red, and white RCA jacks on your computer.
6
Choose a matching pair of ports you have on both your computer and your camcorder.
7
Turn both your computer and camcorder off.
8
Connect your computer and camcorder with the appropriate cable. Turn on both your camcorder and your computer.
Nov 20, 2010 | Computers & Internet
I have 4 samsung tvs. I want to connect camcorder
Get an RCA cable and connect the following to the back of your HDTV:
Yellow - Video
Red- Right Audio
White - Left Audio
The other end should be compatible with the Audio-Video output of your Camcorder... Like a small av-jack.
Jun 12, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Watch camcorder on tv
Most camcorders come with an adapter cable that connects from the camcorder and then has three RCA connections 'Video - yellow', Audio Left 'Red' Audio Right 'White' that you can take and connect to many of the newer style and even older TV sets 'Aux inputs' located on the back, side or even front of the TV screens.
Hope this helps
Blessings,
A/V Media Guy
Nov 21, 2009 | Video Cameras
How can i transfer my video from my sony video camera recorder CCD-TRV615 to my windows xp desktop computer, what cables i need and what else???????
in this case the camera doesn't have a usb for direct conection to the pc. you need a video card with video in it will have a yellow RCA conection. and you will need a program like BLAZE MEDIA PRO, using this method you will strem the video to the pc in real time . it means you havto use the RCA cable you use to plug the camcorder to the TV, connect the yellow color to the back of pc if you have the proper video input. for the audio you will need a 3.5mm cable (like headphone jack) it end in female RCA (RED - WHITE) this will go to the headphone input, or to the line in. depending on the pc.
IF you dont have a video card with video in, you need a Video Capture card.( it will have the 3 RCA conections) and it will include software to record from camera to pc.
let say you were able to connet the camera using any of the two options.
it is time to run Blaze media pro. this is all in one video application, you will have 30 days free trial period, if you like it i will recommend to get it. anyway, after you start the program it will have an option on the right side MORE VIDEO OPTIONS. click on it and it will show you get video from. and it will show you the video from the camcorder.
rewind, press play on camcorder and press record on pc and it will record the video in REAL TIME, like you just to do it in a VCR
Oct 08, 2009 | Sony Handycam CCD-TRV615 Camcorder
Where do i connect the cable to the camcorder so i can view on the tv
you would take the black rca plug opposite end of the red white and yellow plug. plug it into the side of the camcorder it should say a/v out and have a hole to plug it in then take the red white and yellow plugs and plug them into a tv and it should say a/v in then switch the tv to audio video 1 or 2 and it should work
May 17, 2009 | Canon DC210 DVD Camcorder
Connect old camcorder to new PC
JVC has the support page for the GR-SXM260U here: http://support.jvc.com/consumer/product.jsp?modelId=MODL027120&pathId=25&page=3&archive=true. This camcorder can be connected to a TV with the S-video connection (JVC recommends their YTU94146A S-Video cable) or two RCA connections. If you use an RCA composite cable, you use only one of the two audio connections (white) and the yellow video cable.
To connect this camcorder to a computer, you need a USB video capture device and some type of video capture software. Here are two examples: https://www.amazon.com/Diamond-Multimedia-VC500-Video-Capture/dp/B001FAE8MA and https://www.amazon.com/ION-Analog-Digital-Converter-Composite/dp/B002MT7JFQ .
I hope this helps.
Jul 05, 2017 | JVC GR-SXM260U Camcorder
Connecting to my tv
A-V cable will be like below picture having 3 RCA pins Yellow Red & White colors.
Jul 11, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
Canon ES55 camcorder
The camcorder has a port called "Audio Video Out". You need an adapter cable (Canon's cable is the C-250) to connect from this port to a television or VCR. Use the white RCA plug on the cable with the "Audio In" jack and the yellow RCA plug with the "Video In" jack on the television or VCR.
Canon's cable is available from their online store at
http://estore.usa.canon.com/SearchResults.asp?PARENTOID=4764
Feb 13, 2008 | Canon ES55 Camcorder
How to connect cords to camera, vcr and computer
Use the provided cable for your camcorder that includes either a rca (yellow, red, white) end or s-video, component, etc... then plug those into the input of your vcr.  you will need to select the correct setting on your vcr (possibly input 2) to view the camcorder.
Dec 21, 2007 | Sony Handycam DCR-TRV70 Mini DV Digital...
Video Cameras Logo
94 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
