Question about Jazz DV-179 Digital Camera
My Jazz Dv179 Digital Camcorder Won't recharge
I ran out of power so i thought i should recharge it i left it charging over night (the red light indicating a charge was on) but when i tried to turn it on nothing happened. I was very upset because it was my first digital camera and i am always careful with my stuff. if you have a solution please get back to me the instruction manual said nothing about recharging
  • 4 more comments
  • speedbump85 Jan 06, 2009
    i have the same problem have had the camera for two weeks and went to turn it on nothing but the little red flashing light so left it plugged into the wall all nite with the red indicator on and tried it in the morning and nothing again so I dont know whats happening but the battery itself says use designated charger only which I did
  • briandalejoh Jan 09, 2009
    The camera's red light comes on but it won't charge.
    the battery looks rechargable. What is the product number of the wall outlet plug in? Maybe the battery can't be charged forever with a USB.
    Also, if you have the wall plug in the (cheap) instruction manual says the camera should work if you have the right
  • amandae987 Mar 11, 2009
    i lost the camera in the car. it was out there almost all winter. so im sure i killed the battery. chances are your battery was also frozen (before you bought it).
  • Anonymous Mar 12, 2009
    my camcorder have been on the charger all night red light indicating that it is charging but nothing is happening it wont turn on
  • crazy_can629 Mar 17, 2009
    my problem is similar the red light came on...now nothing. It doesn't come on or anything. As well i need to find the manual and the disk for this camcorder (Jazz DV 179) someone please help me.
    crazy_canuck6@hotmail.com
  • Rob Houg
    Rob Houg May 11, 2010
    How are you trying to charge through wall plug or usb cable to camera?
The battery in the camera is likely not a rechargable one. Check the print on the battery. Mine was not so I assume your is not as well. The maker of the camera was pretty cheap not supplying a rechargable battery, for the price they ask for the camera.
Posted on Jan 05, 2009
Will not charge...
probably the bat is dead
Apr 09, 2010 | Jazz DV-179 Digital Camera
Jazz DV179
One possibility is that perhaps the USB port in the back of your computer may not be providing enough power for the camcorder to recharge or operate properly. Do you have another USB port to try?
If you are using desktop computer workstation, you may want to add another USB card to your computer.
Oct 07, 2008 | Jazz DV-179 Digital Camera
Jazz DV 179 Camcorder
I believe that the camera will not charge directly from the computer - testing this theory myself... however I went to Radio Shack tonight and they have them there for 30 bucks (a bit outragious if you as me)
Jul 24, 2008 | Jazz DV-179 Digital Camera
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Recharging Battery
Check to make sure that the battery is seated properly and check the battery posts for wear and tear or corrosion.
Jun 30, 2008 | Jazz DV-179 Digital Camera
Jazz DV179
be sure you are charging the camera with the power plug and not through the usb pplug that does not work that solved my problem
Mar 25, 2008 | Jazz DV-179 Digital Camera
How to recharge the Jazz DV179 camera
attach your usb power cord (it came with the camera in the box) in a power outlet, then attach the usb end into your usb adaptor on the bottom of your buttons panel of your jazz DV179... the light should go on and turn red
Mar 09, 2008 | Jazz DV-179 Digital Camera
Jazz DV179 - Poor video Quality when filming at night.
  • If you can manually change the sensitivity ie iso you will get better images in low light. My digital camera on auto is not good in low light but I do the above and get satisfactory images.good luck...jw
Dec 28, 2007 | Jazz DV-179 Digital Camera
Jazz dv179
The Charger has a standard two pronged plug to go into the wall. The other end goes into the camera at the back bottom. You will see the female received for the male plug.
Dec 18, 2007 | Jazz DV-179 Digital Camera
Jazz DV- 179 Digital camera
the first time i charged approx 5 hrs
Dec 04, 2007 | Jazz DV-179 Digital Camera
Jazz DV-179 Digital Camera Logo
474 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
