Question about Magellan RoadMate 2000 GPS Receiver
Broken Magellan roadmate
Seems its a common problem to break the power plug in. Thats my problem. Any idea of fixing? If you had to replace the board, how much would that cost
  • Anonymous Feb 18, 2009
    power connector has broken off from the circuit board. Can it be repaired?
    President:
  • 1,111 Answers
Robdw71 you can get help through the link near the bottom of this post...good luck
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Posted on Dec 13, 2010
Roadmate 2200t wont charge even after replacing with a new battery
hi rocco_berard
this is a very common problem with your model gps
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
Bill
Jun 29, 2010 | Magellan RoadMate 2200T GPS Receiver
How do you replace the battery in a Magellan Roadmate 1200
there are four hidden screws under the little rubber plugs on the back (unless they are missing) remove those screws, then use your finger nail (thats what i use) to slid it around the seem of the front and back cover to un snap the locks.
carefully seperate them and disconnect the wires off the rear cover thats attached to the board...its pretty easy...just dont be in a hurry
youll see the battery right away and its a simple remove and replace...no soldering or any other nonsense
bill
Apr 19, 2010 | Magellan Roadmate 1200 Car GPS Receiver
LCD replacement for a Magellan 3100
these 3100 and magellan 2000,2200t,2500,3140,4000,4040 and the 4050 are known to have faulty dc connectors...if you magellan gps is not charging or will not power up, its most likey the dc power port...i sell these ports and will repair them for anyone thats not able to do it them selves ....wmetz@comcast.net
ebay id imbmetz1
Jun 20, 2009 | Magellan RoadMate 2200T GPS Receiver
Power problem
is there a reset button you can press? if not try charging it for 10 mins then try and turn it on
Dec 29, 2008 | Magellan RoadMate 300 GPS Receiver
The hole of +- joint for external connection cord was broken
I have found my friend who is very familiar in electionic and small appliances to help me. I can fix it too, but unfortunately I do not have any soldering tools and parts here. I will bring it to Hong Kong and let my friend to fix it. It's very cheap if we find anyone to fix it in China where Magellan is assembled . Thanks.
Dec 28, 2008 | Magellan RoadMate 800 GPS Receiver
Problems with Magellan Maestro? 4040 GPS power connection
this is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan model MAESTRO3100
if you need the power port for your gps, i have them for 2000 2200t 2500 3100 3140 4000 4040 and 4050 magellan maestro and roadmate
Oct 25, 2008 | Magellan SITEX 236/120ST TM 120KHZ -...
MAGELLEN ROADMATE 700 NO POWER
One of the wires in your power cord could be broken. If you have the a/c adapter, see if you can power up with that. If you know someone else with a working Magellan, you could borrow his cord to test your unit.
If not, check the car adapter with a continuity tester. Put one tester probe on one of the side springs of the car plug and the other probe on the outside metal of the GPS plug. If that shows continuity, place one tester probe on the end tip of the car plug and the other inside the the GPS plug.
If either of those do not show continuity, first take apart the auto side of the cord. Check the fuse and the wire to contact solder joints. If they seem okay, carefully cut back the molded plastic from the GPS end and examine the wire to solder joints. If any are broken, replace the cord or resolder the joints.
Nov 02, 2007 | Magellan RoadMate 700 GPS Receiver
Power adapter
Hi, You can get the power adapter pin replaced at an Electronic store. Radio Shack has it but it must be special ordered, have you tested the power cord? I think that you might be right about the power socket cause thats what most common problem of the ones that I repair.
Oct 18, 2007 | Magellan RoadMate 300 GPS Receiver
Magellan Roadmate 800 - External Power Connection
The only thing I can think to add is a general question to Magellan asking why they let a four-year-old child design the power connector as "lightly" soldered to the main circuit board. Very dumb...
Sep 04, 2007 | Magellan RoadMate 800 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
69 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
