Question about Roper RAS6233KQ Top Load Washer
Roper RAS7133KQO Hi, this washing machine is approx. 4 years old and will not drain all the water out of the spin cycle. This machine is my mothers machine and we have a Maytag PAVT234AWW and our machine is doing the same thing! Any ideas...? Thank you, Donna
  • 1 more comment
  • Donna Fleming May 07, 2007
    Hi, its me again with the Roper RAS7133. I was hoping to hear something about my mom's washer machine problem as stated above. It is driving her crazy pleasssse helppppp...Thank YOU!!! Donna
  • shallen2 Mar 23, 2008
    my washer is only 6 months old and the water will not spin out. it just stops when it gets to spin WHY!
  • sslapsshot Aug 29, 2008
    will not spin
Have the piump checked--the pump has to work to get the water out during the spin cycle. wire might be loose, hose might be off...or pump might just be plain broken. new pump is between $35-$50.
Posted on Dec 15, 2007
    President:
  • 1,462 Answers
Check the filter!
Posted on May 12, 2007
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
My Roper washing machine will not drain the water after the wash cycle.
heatman101
Apr 17, 2011 | Roper Washing Machines
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
Making loud noise and not spinning RAS7133KQO
its direct drive. you need to pull the pump and motor and replace the motor coupling. easy fix dont junk it.
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Agitater spins around, water won't drain.
The model number is located under the lid.
Nov 17, 2008 | Roper RAS8445KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
473 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
