Question about Nextar MC3007 (40 GB) Digital Media Player
Nextar pmp mc 3007
Do you know if this multi media player is suppose to break up the recording of one movie into 3 or 4 separate files when it records
I've only recorded 3 videos on this and all three were about an hour or less and I got one single file each time.
Posted on Mar 09, 2009
I can not play movies in my totem movie player, AMR is missing
Hi..
AMR (Adaptive Multi Rate) is common audio file format for mobile devices like mobile phones, laptops, portable recorders.. etc.
in fact totem movie player can't play any amr files (files encoded in amr codec) by itself. Totem Player depends on Gstreamer libs, which haves necessary media handling components .
from your post its not clear that whether your totem can't play movie files from the very beginning or just you can not play movies recently.
your totem player may lacks Gstreamer library files or somehow your Gstreamer libs got corrupted recently.
Reinstalling Gstreamer Library file may help you.
you can find latest source version of Gstreamer on this page
(more detailed download of Gstreamer can be found on http://openports.se/multimedia/gstreamer-0.10 )
Mar 17, 2011 | NEC Computers & Internet
Tip
How to edit Media Center Recordings
Easiest FREE way I've found to edit Recordings made in Windows Media Center is done using Windows Live Movie Maker (Part of the Windows Live Essentials Free Downloads)
I have found that there is some technique involved in making successful edits of the recording.
  1. Open the recording you want to edit in Movie Maker, click save and name the save file what you wish (This file just stores your edit markers and makes no changes to the original recording)
  2. Since most recordings have some overlap, you first need to find the actual beginning and end of the recording, under tools, mark the start and end points using the buttons labeled as such. Click SAVE
  3. Editing the commercials is done in a similiar manner. Browse thru the recording to the start point of the commercial, under tools, click the SPLIT button, then browse to the end of the commercial segment, click split again. (This separates a the commercial portion from the rest of the recording) Right click the commercial segment, Click Delete on the drop down menu and that commercial is deleted (Note the run time is adjusted to the removal point) Click save and repeat on all other commercials.
  4. Once editing is complete, you should have about 22 minutes for a half hour show or 43 minutes for an hour show. Click Save
  5. Here is where I drove myself crazy till I learned the trick. Once edits are saved, CLOSE movie Maker. I don't know exactly why, but I spent a week learning that no matter what I did, 90% of the time when I tried to create movie, movie maker would LOCK UP. Trial and error eventually proved that if I made my edits, then Saved and closed Movie Maker. The re-opened Movie Maker and opened the edit file, that I could then Create Movie successfully every attempt. Click File, Create Movie, and choose your format. (I use widescreen) Saving process is slow, about the length of the show or 1% per minute. This creates a .WMV file about 1/3 the size of the original.
  6. If you want to compress the file even more you can use an encoder to convert the file from WMV to a compressed format (I prefer AVI) I use SUPER © from Erightsoft.com
on Aug 11, 2010 | Computers & Internet
I have old home movies on these tapes.. I am looking into buying the Pinacle Dazzle DVD Recorder (convert) will this convert my tapes to DVD? Does anyone know?
You already have Movies on TDK E-HG 120 VHS tapes; All you want is to Transform the media on the tapes into another record Media or on DVD.
The following process would make possible the project
1. A DVD Recorder device would transform the movies already on one media to another media.
Note: The recorder that would be acquired should have a feed area for the VHS tapes on one hand, to be played, while on the other hand, a DVD disk area from which disk medium would be recorded.
Important Notes.
The devices required to make the process achievable includes
1. The DVD Recorder or Player alsoo known with multi perpose functionality for signal convertion capability
2. The DVD recordable disks on which to record a movies onto.
Caution
The process of recording would require selection features determinable on the recorder device else would produce movies with undesireable features
For example; VHS movies are appear in decodeable formats integral when displayed on VHS players. The caution is to select a signal conversion format suitable for movies that have to transform between recordable media.
1. A DVD disk medium has formats as design specification and on which requires consideration when attempting to transfer multi media or motion pictures.
Type of formats of decodes
NTSA standards
PAL standards
Mescem standards
NOTE;
Whenever the option is available, select NTSA or PAL for appropiate code transformation
Your DVD RECORDER DEVICE SHOULD HAVE THE OPTION TO RECORD CONSIDERING MOVIES ACROSS MEDIUM TYPES
REMEMBER;
consult professional advise before acquiring an devices and mediums
If any consultation is required, refer to user guides or manuals of the devices in question.
Consult a technical expert when the need requires it.
Dec 02, 2010 | TDK E-HG 120 VHS Tape
Compatibility
I have Vista and it works great it just see's it as another drive like a thumbdrive.
Feb 02, 2009 | Coby PMP-3520 (20 GB) Digital Media Player...
My mp3 player is jammed or something
reset the software clear all the songs and reformat it
Jan 05, 2009 | Nextar MA933A MP3 Player
Querry
The media content blocked might be due to a password issue.
The only other thing I suggest you do is download the full CODEC pack which you can get free online. This should let any media player play the files.
Sep 08, 2017 | Coby PMP-4330 Digital Media Player
LG HOME THEATER - FOR PURCHASE
i don't have the the kind of stuff but i go to fry's electronics that i go most of my computer stuff
Apr 08, 2008 | Audio Players & Recorders
Pmp-4330
Do you mean voice or video recording......
whichever it is your problem maybe because of the fact that some players have only a certain limt of space alloted for recording.for example:in a normal 1 gb player with voice recording function only about 28 hrs(approx. 128 MB ) of voice can be recorded....even if there is plenty of space left in the player the player will not record voice once the full 28 hrs has been used................This recording facility can be reused by deleting the old recorded files.....
Hope it helps
Feb 27, 2008 | Coby PMP-4330 Digital Media Player
Cant leav recorded files
Press & hold the centre button. After a couple of seconds your music folder should appear on the display. Select it then press the play button.
Let me know how you get on!
Jan 10, 2008 | Nextar MA566 MP3 Player
Nextar MC3007 (40 GB) Digital Media Player Logo
67 people viewed this question
Top Nextar Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
