Question about Gateway 4026GZ Notebook
Network adapter disable when trying to install wireless router
My broadcom 802.11g network adapter disables whenever I try to install my linksys wireless router to it.
  • Pat Batta
    Pat Batta May 11, 2010
    What do you mean For Install Lynksys Wlan Router?
    You can only configure the Router connecting PC to Router via a cable.
    OR You can configure the WLAN connection in your PC entering WLAN setting + Network key or Passphrase
I have a Broadcom 802.11g Network Adapter and a Cisco/Linksys WRT54GS Router. The signal is extremely poor even though the router is only 10 feet away. It does not appear to be an interference issue.
You can update the Linksys Firmware to a newer version if is available, please check the Linksys support site
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54GS
Another chance is to change the Wireless Channel maybe 11, to avoid any intereference with wireless phones.
Regards,
Mar 13, 2011 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
When I run the set up wizard for my Linkksys WRT160N V3 router, I get the message "Cisco Setup Wizard requires that one wired network adapter be enabled. Error 314: Could Not Disable Wireless...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 04, 2010 | Linksys WRT160N Wireless Router
I have the WRT54G router. I got an adapter for my USB Printer cable to Ethernet to connect it to the router. I have a wireless laptop that I would like to use to send the print jobs to the printer (a...
Connecting to a Wireless Network with SSID Broadcast Disabled when using Windows Vista & Windows 7 Article ID: 5451
Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled, you will have to create a profile.
Creating a Profile
NOTE: Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled you have to create a profile.
Step 1:
Right-click this icon kb_5451-001_en.png at the bottom right-hand corner of the screen, then select Network and Sharing Center.
NOTE: If you are using Windows 7, just click once on this icon kb_5451-003_en.png at the bottom-right of the screen then select Open Network and Sharing Center.
On the Network and Sharing Center window, click Manage wireless networks.
Step 3:
Click Add. NOTE: You have to remove your preferred network before before you proceed to click Add a new connection. If you see your network has changed from Automatic to Manual, you will face difficulties to connect your computer on the network because the SSID is not broadcasting into the available network connection. After removing your preferred network and adding it back, the network will turn to Automatic and you will be able to connect automatically into your network. Make sure to look at network properties/Connection and check "Connect when this network is in range".
Keep reading here
Jul 10, 2010 | Linksys Wireless-G WRT54G Router
I've tried to wireless adaptors in this machine
Are your drivers for XP 64? If not, they will not work.
Sep 28, 2009 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
Wireless-g usb adapter fails to connect to router
if your wireless router has security enabled, as a first troubleshooting step you can try disabling the security. then see if the USB adapter can connect. IF it still cannot conenct check for the default channel on the router and on the adapter side.
Jun 03, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
My broadcom 802.11g network adapter disables every time I try to connect it to my linksys wireless router.
Check the various wireless access points near you, if any of them are broadcasting on the same channel as your wireless router, then change it to a channel that is unused.
Also check the signal strength of your wireless router, if it is less than say 60% move your laptop or your wireless router away from walls (especially concrete walls and metal/foil walls) and locate it higher to improve radio reception.
Dec 29, 2008 | Computers & Internet
Broadcom 802.11 g/b WLAN Problem
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
Jun 04, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
May 17, 2007 | Linksys Wireless-G WRT54G Router
Gateway 4026GZ Notebook Logo
89 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
