Question about Samsung HCM4215W 42" Rear Projection Television
Power supply TV does not turns on, only a red light comes up. Do not know if this is the only problem it has.
  • 1 more comment
  • Anonymous Nov 06, 2007
    when I turn the power on the red timer light flashed, the tv makes taht noise that tells you it is coming on but then the red light flashes again and it makes the noise and just continues to do this without ever coming on.
  • stinah Nov 13, 2007
    My Samsung HCM4215W has the same problem, when you turn it on, the red light comes on for a few seconds then goes off. We put in new stk chips prior to this and it showed pictures clearly but after a couple of weeks it developed this power problem. Took it to a technician and they claim the motherboard is not supplying power. What can we do now??
  • pyrox02 Dec 05, 2007
    I'm not sure if all of us posting here have the same problem, but my problem is at least similar to one of the above. I posted this by itself on the site, but I think it's relevant here. Sorry for the double-post in advance.
    I have a problem described by at least two other users. As stated, the
    tv will look as though it is about to power up, will make the
    "power-up" noise, and then remain black, and then the power-up noise,
    in an infinite loop. In fact, this begins as soon as the TV is plugged
    in, without any prompting.
    Some clicking/ popping does occur
    while the TV is going through this process. I'd describe it as not too
    far from sounding like the normal clicks a TV makes while it is
    starting up.
    Earlier in the day (when the problem first
    occurred), if I would wait long enough, I would hear a second or 2 of
    audio from what I was watching, which would then be silenced, and then
    come back on, with no pattern that I could tell. That is no longer
    occurring, or maybe I'm not leaving the TV on long enough to hear it.
    The
    red light below the word "TIMER" lights up erratically, sometimes
    blinking at an even pace, sometimes staying lit for a long time, and
    sometimes blinking quickly in and out.
    There is no smell associated with this issue that I can tell.
    When
    the problem first occurred this morning, my image was normal and then
    suddenly went black, except for different-colored lines in a bowtie
    shape converging in the middle of the screen, before it went entirely
    black.
    Remote functions were still working earlier, as I was
    able to switch from playing a game to antenna A after the screen went
    out. (I could tell by the little bits of audio that came through.)
    Not
    sure if it's of any importance, but before this event occurred I had
    only used the TV for approximately 1.5 hours. However, I had used it
    for 4-6 hours straight about 8 hours before I began using it this
    morning.
    Thank you in advance.
Try unplugging the red connector on the IC board (the board with the 2 stk chips) and try to turn it on, the picture will look pretty crappy but if it comes on it is probably the stkxxx-xxx chips replace with oem parts or you will be doing this again soon.
Posted on Oct 01, 2007
  • 97 Answers
Sounds like you only have the stanby circuit function on the power supply. More information is needed to help further. Does it have a smell to it? Can you hear any relays tripping over? Can you hear high voltage build to the tubes?
Posted on Apr 29, 2007
Tv does not turn on
try to on power supply with dummy load
Nov 16, 2013 | RCA 22LA45RQ TV
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Jul 02, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
The red light in the bottom left corner keeps blinking and it wont turn on. Yet when i unplug the tv and plug it back in the blue light comes on but then turns into red light blinking again and it wont...
Ur tv power supply board have dead componnents call capacitors.These capacitors are leaking gas,and it bulges up on it top or puff up on it top.These capacitors parts are dead,they must be replaced.U know basic electronic's and soldering?Take ur tv aparts,the board where the power cord plug into it.That ur power supply board,searches all around for these dead gas leakage capacitors,replaced them.Ur tv power LED light will be stable and the tv power will work again.Or tries websites like Shopjimmy.com,ebay.com to buy a whole reburbish power supply board for the replacement.
May 24, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
I cant get the tv to come on it has power
You have a bad power supply (AC adapter). Watch closely at the red light while turning tv on to see if red light momentarily flashes green, then back to red.
Dec 15, 2008 | Proscan 19LA25Q 19 in. LCD Television
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung HCM4215W 42" Rear Projection Television Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
