My broadcom 802.11g network adapter disables every time I try to connect it to my linksys wireless router.
  • 32,281 Answers
Check the various wireless access points near you, if any of them are broadcasting on the same channel as your wireless router, then change it to a channel that is unused.
Also check the signal strength of your wireless router, if it is less than say 60% move your laptop or your wireless router away from walls (especially concrete walls and metal/foil walls) and locate it higher to improve radio reception.
Posted on Dec 29, 2008
I have a Broadcom 802.11g Network Adapter and a Cisco/Linksys WRT54GS Router. The signal is extremely poor even though the router is only 10 feet away. It does not appear to be an interference issue.
You can update the Linksys Firmware to a newer version if is available, please check the Linksys support site
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54GS
Another chance is to change the Wireless Channel maybe 11, to avoid any intereference with wireless phones.
Regards,
Mar 13, 2011 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
Hi experts! I recently purchased HP tx2-1025dx with Broadcom 4321AG 802.11a/b/g/draft-n Wi-Fi Adapter preinctalled. have no idea why my connection (I have cable) is so slow not only home, but at Wi-Fi...
Wireless N is not standardized yet. The design(features & functions) will depend on the manufacturers. It is not advisable to use wireless N products from different manufacturers since they have it designed differently.
To maximize the features & functions of wireless N you need to have compatible devices. Meaning, I you're using let's say Linksys N router you need to use Linksys wireless N adapter.
Jun 08, 2009 | Broadcom BCM5705 Network Adapter
Wireless-g usb adapter fails to connect to router
if your wireless router has security enabled, as a first troubleshooting step you can try disabling the security. then see if the USB adapter can connect. IF it still cannot conenct check for the default channel on the router and on the adapter side.
Jun 03, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Brand new linksys wireless, Host (Hard wired)has intermittent connectivity. Indicates it is conneted and is working properly.Cannot browse Web. The wireless part works great!
try to plug the Ethernet cord for the Host computer on another Ethernet port on the Linksys router.
have you tried replacing the Ethernet cable that's connecting the Host computer to the linksys router?
check if Host computer can get a response from a website by going to Start>Run, then type CMD on the Run box and click OK. On the black screen, type PING www.yahoo.com then press Enter.. if you get the word reply 4 times, it means the computer is connected to the Internet.
If there's no response from the PING test, it means there's totally no connection.
It's also possible the problem is with the Local Area Network adapter or Ethernet adapter. Try disabling the Ethernet adapter and re-enable it by going to Start>Control Panel>Network Connections, you should see the Local Area Connection, right click on it then select Disable then Enable it again. then observe if you're still experiencing intermittent connection on the Host computer.
and if you have security software, try disabling it temporarily and check the connection again.
and let's make sure the cable or dsl modem is connected to the Internet port on the back of the Linksys router.
May 10, 2009 | Linksys WRT160N Wireless Router
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Wireless Network Disconnecting
u have to reset your wifi router.
reset switch is in back of router and configure asgain.if u not need static ip then comfigure as dhcp
Jan 06, 2009 | Linksys WRT160N Wireless Router
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Broadcom 802.11 g/b WLAN Problem
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
Jun 04, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
May 17, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
