Question about iLO 3200 32 in. LCD Television
ILO 32 inch TV
I can operate everything (vcr, computer) but cannot get my tv cable hooked into the tv. The traditional connection doesn't fit into the TV, so I must go through a VCR. Help!
The TV should have two ANT coax jacks in the back, one for air and one for the cable line. The one on the right side should be the one you want. It could be that you've plugged it into the left one, which will not work for line cable.
Posted on May 02, 2007
SOURCE:
My ilo hdtv doesn't have a cable hook up
Going to have to connect (no coax fitting means it is a monitor with no tuner) via one of the rear audio/video inputs with a box that has those outputs on it.
HD is almost always connected in this way.
May 02, 2012 | iLO IWT3206 TV
Cable hook up
you can put in a new tuner or if you are good you might be able to fix the one you have but anyway it needs a new tuner. This tv is made by funai FAX number is 614-497-2720 phone number is 614-497-2689 these are the numbers I have for them at this time they are in Lockbourne ,Ohio
Mar 10, 2009 | iLO IWT3206 TV
Element FLX 3210 not scanning for cable channels
YOU HAVE A BAD TUNER OR RF INPUT. IF YOU CONNECT THE CABLE TO THE VCR AND THEN USE THE VIDEO OUTPUT OF THE VCR TO THE VIDEO INPUT OF THE TV YOU CAN USE THE TUNER IN THE VCR TO CHANGE CHANNELS.
Jan 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Cant get vcr to work
is your vcr capable of hd output? if not the picture will be a bit distorted(stretched)
Apr 21, 2008 | iLO 3200 32 in. LCD Television
Problemw with digital TV signal using an arieal
I recently purchased an ilo 32 inch tv and am having problems because when I first purchased it I had it connected to a cable box now I no longer have the cable box just the cable and am unable to hook it up because the connecter does not hook up to a regular cable cord is there a special connection that hooks it up directly to the cable cord? I read in the manual something about a F-type connector where can I get one?
Mar 28, 2008 | Televison & Video
ILO color
First thing to do is see if this happens on ALL inputs so you can pin piont the Tv and not the source. if it still happens the only way to repair this type of problem would be to replace the main board for this set
Feb 11, 2008 | iLO V27DMBX Television
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
AM/FM Stereo Hookup problems
Make sure your audio outputs are turned on.Also try a connection from the tv straight to the stereo to see if you have sound !! If so then the problem is somewhere in between!! Check the settings for audio on these devices as well !! Good Luck !!1 Swampratt200 AAAAAAAAAAAAAAEEEEEEEEEE!!!!
Nov 03, 2007 | iLO 3200 32 in. LCD Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
iLO 3200 32 in. LCD Television Logo
110 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
