Question about Magellan RoadMate 300 GPS Receiver
Power problem My Magellan Roadmate 300 worked fine yesterday, today I go to turn it on and it won't power on. It is plugged into the cigarette lighter and the green light is on, acknowleging it is getting power, but when i push and hold the button it will not turn on. Any ideas or solutions would be appreciated. Thanks
  • amanda1486 Dec 29, 2008
    I do not see a reset button... and it charges while it is in the cigarette lighter.
THE CENTER PIN IN THE UNIT FOR THE POWER CORD BREAKS VERY EASILY ON THESE UNITS,,,,,MAKING IT UNUSABLE WITHOUT REPAIR.....ITS PRETTY MUCH TRASH
Posted on Jan 01, 2009
Is there a reset button you can press? if not try charging it for 10 mins then try and turn it on
Posted on Dec 29, 2008
My Magellan Roadmate doesn't work anymore when I plug it into my cigarette lighter. It says the battery is low and it is shutting down. The unit did not come with a battery charger so I am confused about...
there could be a few reasons why this is happening....
there should be a light on the car charger that comes on when you plug it in, if it isnt on when not plugged in to the gps, but while plugged in to the lighter...either the lighter fuse is blown, or the charger is defective.
if the light is on, on the charger and it still wont stay powered on, it probably has a bad usb port (very common on this model) but it could also mean the charger (if not factory) is not compaible with the unit.
another way you can try and charge it (if you determine the chargers at fault) is to hook it up to your computer via the usb cord that should of been supplied with your unit.
HERE is your manual..it will show you the differant charging options..there is also updates on that page if you need them
let me know if you need more help.
bill
Aug 17, 2010 | Magellan RoadMate 1470 GPS Receiver
Magellan RoadMate 3000T. When plugged into the cigarette lighter, I only get a little red light in the upper right corner. How do I turn it on? I can't understand their symbols. (it is a hand me down from...
Download the manual from here.
The LED in the upper right corner seems to be a charging indicator, so this means that the power supply via the cigarette lighter seems to be ok.
To switch it on, press and hold the power button for 3 or 10 seconds (depends on the state of the device - whether in sleep mode or off).
Mar 11, 2010 | Magellan RoadMate 3000T GPS Receiver
Magellan RoadMate won't compute if connected to power
unplug the charger, then turn the 1200 on, once its fully booted, hold the power button for 15 seconds..the screen will go blank after a few seconds, but continue to hold it for 15 seconds.
now, with the charger plugged in and unit off, press and hold the power button for upto 7 seconds or till it starts.
if that fails, let me know and i can tell you something else to do.
bill
Jan 23, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Unit will not turn on.
i just answered your last post regarding this magellan 300.
bill
Aug 26, 2009 | Magellan RoadMate 300 GPS Receiver
Magellan roadmate 300 wont stay on
It is the cigarette adapter, mine was doing the same thing until I bought a new adapter. When the old adapter plug to the GPS unit moved at all it would lose power.
Jan 13, 2008 | Magellan RoadMate 300 GPS Receiver
Won't Power from Cigarette lighter
Recently I had a similar problem with my 300 - worked fine with AC power, but was intermittent with the power point in my truck sometimes it wouldn't power up at all in the truck).
I used a small nail file (steel wool would work too) to break the "glaze" on the outside of the small plug that plugs in to the unit on the power cord. It seems that it wasn't getting a good ground. Has been working great ever since - worth a try.
Dec 12, 2007 | Magellan RoadMate 300 GPS Receiver
Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Nov 30, 2007 | Magellan RoadMate 300 GPS Receiver
No power to unit, but powers on okay in house with AC power adapter
Not sure if you'll see this post, as you asked the question back in Nov, but I
thought I'd tell you what I know anyway.
I and my parents bought the same exact unit within a week of each other.
There's works, and mine does not.
I took their cradle, and hooked it to my GPS, and it came on, no problem.
I took my cradle, and hooked it to theirs, and boom, nothing.
So, with that, I was able to isolate that the problem is definitely in the cradle.
I went to the manufacturer website, registered my Magellan Roadmate 700,
and then I was able to contact customer support. I am writing to you as
I wait for their reply. Here's their website.
https://www.magellangps.com/users/registrationHelp.asp
Hope this helps!
Nov 12, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 800 - External Power Connection
The only thing I can think to add is a general question to Magellan asking why they let a four-year-old child design the power connector as "lightly" soldered to the main circuit board. Very dumb...
Sep 04, 2007 | Magellan RoadMate 800 GPS Receiver
Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Jul 20, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 300 GPS Receiver Logo
261 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
