Question about Chicago Forge AF5HV 30 - Gal. 5.0 - HP Vertical Air Compressor
My husky pro vt631402aj verticle compressor won't stay running when compression rises
    Problem Solver:
  • 5 Answers
Hello,check to see if it cuts off at the same psi each time.If so,youneed to adjust the pressure switch to the tank to the max & adjust the pressure to the tool you want to run with the pressure out kob.Hope this helps
Posted on Dec 29, 2008
Husky air compressor repair
Are you meaning that you cannot adjust the regulator to change the pressure output?
Jun 01, 2013 | Husky Factory Reconditioned Electric Air...
Husky pancake compressor won't fill
have you checked the ring and cylider or the valves?
Jan 02, 2013 | Stanley FactoryReconditioned Bostitch...
I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
Nov 13, 2009 | Porter Cable Air Tools & Compressors
I have a husky pro air compressor that fails under load. 3hp, 60t
sounds like bad seals to me, maybe the rubbers have perished.
Sep 07, 2009 | 2004 Sym Husky 125
My verticle vt631402aj compressor motor boggs down before pressure can reach 15 lbs.
hi your problem sounds tp be associated with your nonreturn valve this is not sealing ,allowing pressure to flow back to your pump from your reciever/tank ,this is a"service part"and do require replacement periodically
hope this is of help ian
Dec 29, 2008 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Chicago Forge AF5HV 30 - Gal. 5.0 - HP Vertical Air Compressor Logo
1,401 people viewed this question
Top Chicago Forge Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Chicago Forge Air Tool and Compressor Expert? Answer questions, earn points and help others
