Question about BenQ FP737S-D 17" LCD Monitor
The monitor settings are lowest and cannot be changed
The screen resolution is 640 by 480, the colour is 4-bit and there are no other options to change to
    Genius:
  • 1,066 Answers
You prolly need to reinstall the drivers for your video card. check to manufacturer's website for the appropriate dtrivers
Posted on Dec 29, 2008
Hi. The colour on my HP/Compaq 6820s laptop is a bit dull in comparison to my second extended Samsung monitor. I want to adjust the colour settings on the laptop, but all I can find on the keyboard is...
If you right hand mouse click on your desktop picture, a menu will become available. Click on Screen resolution and then Advanced settings. There will be options inside that window to allow you adjustment of the display.
Hope that helps.
Nov 25, 2010 | HP Smart Buy - HP Compaq 6820s Notebook PC...
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
Out of range
Your windows video settings are for a monitor that has more capability (eg more pixels/finer resolution, higher refresh rate, more colour bits than the current screen can handle so it's spit the dummy.
Run your computer in safe mode (I believe that uses basic video driver) and set the video display options to a very low level, then re-start your computer again in normal mode, and set the options to the native resolution, refresh rate etc of the monitor. These should be listed in the specs that would come in the box with it (may be resolution: 1,680x1,050)
Sep 13, 2009 | ViewSonic VX2235wm LCD Monitor
Medion monitor shows analog out of range and will not turn on
Two options here. 1) Boot into safe mode, open control panel, display, settings, change the screen resolution to the lowest setting and color quality to their lowest setting and reboot. If that works move your setting up to where you used to have it (i.e. 800x600 pixels. Another option is to use System Restore to restore your system to an earlier date...a program you recently installed could be the culprit. System Restore is located at Start, All Programs, Accessories, System Tools.
Jan 14, 2009 | LG Flatron L1750S 17" LCD Monitor
Flicker and Noice
1.try to change a screen resolution on your monitor. if did not solve your problem
2.change the colour quality either 32 bit or 16 bit
try your best.
please rate this solution whenever.
Sep 16, 2008 | Acer 22" X223w LCD Monitor
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
RM computer-
be sure you downloaded the graphic driver for your computer. you can find it from the manufacturer website or if you know the model of your mainboard you can also find it from the mainboard manufacturer website. also, try changing your display settings by right click your desktop and choose properties then choose display adjust the screen resolution on higher pixel. but my best guess is you need the graphic driver of your computer.
Feb 21, 2008 | Ahead Software Nero 6.0 (60045) for PC
BenQ FP737S-D 17" LCD Monitor Logo
51 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
