Question about RCA P52930BL 52" Rear Projection Television
Hourglassing Hello, I have a 8 to 10 year old RCA 52" TV that is hourglassing. I was wondering how to fix this and if it's something I can do myself. Thanks so much.
  • 97 Answers
This problem is the "pincussion" setup on the convergence board. It, however can be caused by a failing power supply. If the set takes more than 60 seconds to produce the picture and up to 10 minutes to fully produce a good picture, even with the problem, power supply. Most likely if it does not do the mentioned it is the pin amp on the convergence board.
Posted on Apr 29, 2007
SOURCE:
I have an hourglass image on the screen and the colors where the screen warps are all separated. I was wondering if that can be fixed or if the tv isn't worth it. Thanks for the help
yes it is fixable and way cheaper than buying a new one all u have to do is change the convergence they are 2 IC's usually located in the video board attached to a aluminum heat sink side by side.
Jan 29, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 in RCA projection hdtv picture keeps going in and out has soun
If you can solder yes you can fix it your self Ck 3 capacitors cp110 cp114 cp150 --- If cp 150 is puffed up on top it is bad 2200uf 16v other 2 are 220uf 35v replace all3. also resolder all pinns on FBT flyback transfomer and make sure both ribbon connectors are in good.
Jul 20, 2009 | RCA HD52W151 52" Rear Projection HDTV
RCA model P60812BL 10 years old picture goes fuzzy once on
Your convergence amplifiers are begining to malfunction. This is not expensive However I would advise that you get a qualified TV technician to work on the set due to a chance of damaging you TV if you install the amplifiers incorrectly.
I hope this helps
thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | RCA D52W19 52" Rear Projection Television
My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
May 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you have....is this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
61 in RCA Rear-Project color seperation
Your used TV is not worth much. Let us not fill our land fills with TV's. You may give it to a charitable oranganization (tax deduction) or local school that has an electronic course. Enjoy your new LCD you a great choice in type and brand.
May 04, 2008 | RCA P52926 52" Rear Projection Television
Picture coming on then goes out black
When the set goes off, does it die completly or do you still have audio through the TV speakers? If the whole set goes dead, it could be a High Voltage shutdown problem or something more simple like a bad solder connection in the power supply. You will need a Tech to look at it to determine the best course of action. In the past, RCA has had huge problems with solder connections that they made good after the warranty period ended, but overall, after the company was bought by a French outfit, it was never the same, and I've been repairing them since 1976. Their reliability did allow me to send two kids to college, and I do own a trade-in 60" RCA projection TV for myself that I plan to keep for about another year before going HDTV myself.
Dec 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA P52927 52 in. Projection TV
You have a convergence problem, try unplugging power for 5 minutes. Call factory authorized service center.
Nov 18, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
80 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
