Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
I have a 42" flat Phillips plasma TV. I believe the model number is 42PF7220A/37. I did turn on the TV and was on for few seconds. The imagen was gone for other few seconds and turn off by self; a red light blinkin 7 times on front of the tV
  • 24 Answers
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
Menu screen keeps popping up
You can start here: http://www.support.philips.com/support/catalog/catalog.jsp;jsessionid=87CE21B6A8264B83B8D00501ADACA8BF.app107-drp1?_dyncharset=UTF-8&country=&categoryid=FLAT_TV_CA_US_CARE&userLanguage=en&navCount=1&groupId=TV_GR_US_CARE&catalogType=&navAction=push&userCountry=us&title=Flat+TV+(plasma%2C+LCD)
Enter the exact Model Numbere in the search text field.
First verify the exact Model Number of your TV. Mine is a 42PF7220A/37.
go to:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7220A/37&scy=us&slg=en
On this page I found listed under "Software & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
I downloaded the compressed file and extracted it to a USB Flash Drive2.gif.
After you extract the file you will have 2 files...."autorun.upg" and a "readme.txt".
Print out the readme file the delete it off the USB Flash Drive
Make sure the USB Flash Drive2.gif has only one file on it (autorun.upg)
Then just follow the instructions from the "readme" file.
Fixed the "Menu" problem for me.....
Aug 08, 2009 | Philips 42PF7220A 42 in. Plasma Television
Bottom half of the screen goes black frequently.
go to:
On this page I found listed under "Software2.gif & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
Make sure the TV is turned off.
Put the USB Flash Drive in any of the USB ports on the TV.
Turn the TV power on with the Power Button on the righthand side of the TV.
The TV will display an Update screen.
Let the TV run through all 3 processes.
Turn the TV off and remove the USB Flash Drive.
Power the TV back up.
Hopefully the Updates fixed the problem.....
Jul 27, 2009 | Philips 42PF7220A 42 in. Plasma Television
Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
Apr 17, 2008 | Philips 42PF7220A 42 in. Plasma Television
Settings screen keeps coming on
Remove the batteries from the remote and see if it still happens. If not, then you have a stuck button on the remote. If it continues, then it is a TV problem.
Apr 06, 2008 | Philips 42PF7220A 42 in. Plasma Television
Phillips 427220a
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Mar 08, 2008 | Philips 42PF7220A 42 in. Plasma Television
Phillips TV- Plasma Model #42PF7220A/37
A tech will need to come out. When the tech do come out have him unplug the Y main and see if the led goes solid greem if it does have them replace the Ymain and the Y upper/lower boards. Most likely that will be the problem.
Feb 29, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7220A/37 42" Plasma TV
Feb 09, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips plasma 42pf5520d pictures has gone?
My Philips Plasma TV model 42PF7220A/37 went into "no menu exit" mode on 11/28/2007. I went to www.usasupport.philips.com and downloaded an upgrade. Just followed the instructions and my TV is all better.
Nov 21, 2007 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
255 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
