Question about Dell E151FP 15" Active Matrix TFT LCD Monitor
Dell LCD screen goes white
Screen now goes white immediately it the beginning it would go white after it was in use for a while. Now it is almost immediately. I have removed the cover from the back of the LCD panel. However I do not see any obvious signs of a component being bad....can someone direct me to the part that usually is the issue? I have two fo these monitors currently with this problem. Unfortunately I have several of these in use and I am concerned they too will start having the same problem.
thanks in advance for any help I have the same problem. When my monitor comes on it is all white and stays that way. I have connected it to a different computor and the problem is still there. I'm looking for a higher technical explanation of the problem. I have a Dell 15" LCD that I just got from someone on Freecycle. It practically seems like some kind of RPG (game) where you just keep levelling up to more and more difficult problems. Past monitors have had obvious damage, a blown inverter, power board, etc., but this is a stumper.
It doesn't always start up white. And out of nowhere it'll just fully kick in and out... suddenly BAM, all white. Then I can just leave it on white for a while, and it'll go back to the normal screen. No amount of powering-on-and-off will convince it otherwise. No bashing it upside the head. Nothing is overheating either. It's got no rhyme or reason... it'll do it cold, warm, been on for hours or just minutes. It'll just go all white all of a sudden.
I sort of guess bad capacitors since that seems to always fix my electronics quirks (like the "close cover" error on the LaserJet IIP caused by a bad capacitor on the density control PCB). But is there anyone that can put a more direct finger on the problem?
  • 1 more comment
  • Matt Falcon
    Matt Falcon Dec 29, 2008
    Wow, uh... fixya fails MISERABLY at formatting. I didn't write all that, I just added a comment. My comment begins in paragraph #2 at "I'm looking for a higher technical explanation of the problem".
  • Matt Falcon
    A VGA cable would make the screen go white? All-white means the LCD integrated circuits aren't getting power or signal from the controller logic, presumably that the controller logic became locked up or jammed. Don't see how that could be the VGA cable - or inverter board either for that matter, since the inverter board is what would make the screen dark, not light ;)
    That only leaves the power supply, which appears to be working fine. Switching power supplies have a feedback-loop circuit that either put out "good power", or they just don't work at all, the only possible problem could be "dirty power" from dead capacitors, which I can't test for without having a scopemeter or oscilloscope (a tool high on my to-get list, right next to a capacitance meter).
    But thanks for the reply!
  • Matt Falcon
    Matt Falcon May 31, 2009
    After all this time, I finally found the cause, and hence the solution! There is a poorly soldered component on the power board (I didn't even think to check the power board). I had tried everything else... sanding down (with ultra fine grit paper to remove corrosion) the connector cables, pressing them harder, testing the logic IC for cold solders, everything! I finally decided to try "tapping around" on the board (since banging it across the top would fix it for a while) and locating the tap-sensitive part. I found that a swift (but not very hard) whack on the logic IC made it spring back to life, so I was "getting warm". Nothing I would tap on the LCD panel's components would make it work, so those were OK...
    It wasn't until I started tapping around on components of the power board that I found the exact component with the faulty solder joint. I tapped the area of the circled component (below) very lightly, and it would work great! Voila. I took out the power board, and found that one of the two leads on that component was sliding in and out of its hole (totally loose). That's why bashing it across the top worked (the component is near the top of the monitor). Soldered it back down and it works flawlessly - tapping it no longer causes the screen to go white.
    Who'd've thought it was a faulty solder on the power PCB?
    Problem Solver:
  • 11 Answers
The problem with most LCD monitors that go white are one or more of the following in order:
1. Bad or loose VGA/DVI connection cable
2. Bad power inverter board. (Internal part: can be replaced)
3. Bad power supply.
Hope this helps you.
Posted on Dec 29, 2008
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
For the last 3months,my dell vostro 1088 laptop has started giving a lot of trouble.While i'm doing working on it,the screen suddenly starts blinking and it all goes white within a second.This pro
  • Remove the battery and disconnect the power cord.
  • Press power button for a few second.
  • Connect the power cord. Press the power button to start and then dock the battery.
  • White screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard. The issue can arise with the motherboard or the screen might contain a defect.
Aug 22, 2012 | Dell Vostro 1088
White screen
the beginning of ugly problems you will need a new video driver card and screen within about 3 to 6 months
May 28, 2012 | Dell Inspiron 1545 Black Intel Celeron 900...
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
Screen goes white
Check the ribbon cable between the LCD panel T-CON board and the logic board. When you lose 5vdc feeding the LCD T-CON board the screen will glow white.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 31, 2010 | Dell E176FP 17" LCD Monitor
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Hi...there,
It's seems you got unstable AD board that caused a white screen. Need to be replaced a new ones or updated the bios. What's the AD board? AD board is a piece of component that connecting the VGA or DVI cables. Order from Dell... I'm sure they got lots of refurbished parts laid around... Have a nice day!
Oct 07, 2008 | Sony SDM M51 15.1" LCD Monitor
Dell E151FP 15" Active Matrix TFT LCD Monitor Logo
1,183 people viewed this question
Alun Cox
