Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Logo
Anonymous Posted on Sep 30, 2012
Aperture ring won't turn
Both my zoom and my aperture rings got stuck, I managed to get my zoom working again but my aperture won't turn and makes a scratchy noise when I try to.
  • kakima Sep 30, 2012
    This lens doesn't have an aperture ring. Do you mean the focus ring? If so, do you have autofocus turned off on the camera body?
  • Anonymous Sep 30, 2012
    yeah I mean't the focus ring, I didn't mean aperture ring I did that thing when you say something out loud and accidently type it haha! And I switched it to manual focus and it's not jammed anymore, it's only jammed when it's on autofocus, do you know what that means?:) Thanks!
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Sep 30, 2012
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443033
Points
622693
When the camera is set to autofocus, let the camera do the focusing. If you want to focus manually, turn off the autofocus so you can turn the focusing ring.
    thankyou very much!:)
5 Related Answers
Anonymous
  • Posted on Apr 01, 2009
SOURCE: The Zoom ring is stuck
My lens started catching as I zoomed in and out and would not go wider than ~24mm. The problem is one or more of the screws holding the zoom mechanism comes loose and jams. Follow this link for the fix; took me ~20 min to repair (I went very slowly)! Much easier than taking it apart from the rear.
http://photo.net/nikon-camera-forum/00Pegi
Good luck...
-David
Anonymous
  • 3006 Answers
  • Posted on Jul 19, 2009
SOURCE: zoom stuck, and loose ring of plastic in the
Your lens is totally beyond economic repair, sorry. I've looked into repairing the same fault on this lens before. It's only the basic kit lens as supplied with the camera so it was built with low cost as an overriding primary concern and no real thought for future repairs or spares availability.
The good news is that there are normally a fair number of these lenses both used and brand new at relatively low prices. many owners sell the kit version to upgrade to a better lens and many retailers often have new unboxed (usually ex-display) kit lenses for around 30% less than the new and boxed versions.
Anonymous
  • 291 Answers
  • Posted on Apr 06, 2010
SOURCE: nikon24-120 vr 1 aperture blade kock zoom ring
These lenses are highly complicated, and require adjustment after reassembly. Even if you do get it fixed, you do not have the necessary adjustment software to get it working properly. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and factory trained with all the necessary equipment. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Anonymous
  • 291 Answers
SOURCE: nikon 80 - 400 vr, have to pull lens out to zoom,
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Anonymous
  • 291 Answers
SOURCE: dropped camera: aperture ring will not turn
If you take it apart, you will have to realign it perfectly, and then have it calibrated with special software. Your best bet is to Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
I have a Quantaray 28-200mm AF zoom lens Nikon, I use Nikon D80, are they compatible?
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as with a lens without an aperture ring.
My Nikon F80 won't load y film automatically, it has a FEE error on the screen but i don't know what that is??
The lens you are using has the aperture ring set to something the camera cannot use. Simply turn the aperture ring to the largest number, usually a 22 or 32. Lock that ring if there is a lock and the fee should be gone.
3helpful
How can I use the aperture ring instead of set it to minimum in order to use the ring not the dial. I am trying to operate this way with an AF lens (not af-s) and my d5100.
Set the aperture ring to its minimum setting (largest f/number) and leave it there. You control the aperture from the camera body, exactly the same way as on a lens without an aperture ring. In the A mode, simply turn the command dial. In the M mode, hold down the aperture (exposure compensation) button and turn the command dial.
My fisheye lens f stop is stuck
You didn't provide the name or model lens, so I can provide generic assistance that applies to many lenses. Hopefully, it will work for you.
Many lenses need to be set to the smallest aperture setting in order to be controlled by the camera. If it is moved off this value, the camera will be unable to change the f-stop value. If it is stuck - meaning the camera can't change it - make sure it is set for the smallest opening (highest number 28, 32, etc.). If it is stuck meaning you are unable to twist the aperture ring on the lens barrel to manually change the setting, look for a small tab that engages the aperture ring. They are often employed to prevent accidental movement of the aperture ring off of the smallest opening.
What is the little red button on the lense on the end that screw to the camera that has a red L
That's the aperture lock lever. On many Nikon cameras, the lens needs to have the aperture ring turned to f/32 and locked in place. You then control the aperture from the camera body, the same way as on a lens without an aperture ring.
On older Nikon cameras, you unlock the aperture ring and control the aperture by turning the ring.
Hey there! I'm so glad for sites like these! Well, the point is, I got a FEE error on my NIKON D80 after putting on an old NIKON 28-85mm AF macro lens. Actually on aperture F22 it's working...
Leave the aperture ring on the lens at f/22. You can control the aperture from the camera body, the same way as on a lens without an aperture ring, by turning the command dial.
1helpful
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
3helpful
3answers
The f stop say ee
You're apparently using a lens with an aperture ring. Turn it to its smallest aperture (largest f/number). You control the aperture from the camera body, the same way as on a lens without an aperture ring.
If the lens doesn't have an aperture ring, clean the electrical contacts on the back of the lens and in the lens mount.
1helpful
Hello, I just brought my sigma macro 105mm lens and Im having trouble getting it to work probably on my nikon d90, they only way I can get it to work is turn the aperture on the lens to f32 I cant change...
Turn the aperture ring to f/32 and leave it there. After that, forget the lens has an aperture ring at all. You can let the camera control the aperture in any mode except the M and A modes. In the M and A modes, you control the aperture by turning the command dial on the front of the camera, the same way you control the aperture on a lens without an aperture ring.
I have a Nikon D80 and it is flashing "off"
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
