Question about Garden
96 inch fluorescent light only one bulb will burn have changed bulbs and balist
    President:
  • 2,692 Answers
If it is wired correctly,the only thng left is the tomestones, the contacts that the bulb connects to. Try this ;switch the two wires from the one bulb at the ballast to the other bulb on the ballast. If the other bulb now lights then the new ballast is bad and need to be exchanged.
Posted on Dec 29, 2008
I change my bathroom vent light. Before light went out. When I would turn the light on. It just came on. Now with new light, it flickers then comes on. And my hall bathroom started doing it too once I...
It sounds like you have indeed bought fluorescent bulbs. manufacturers are encouraged to replace the incandescent bulbs with more energy saving fluorescent bulbs. They are made to look like standard bulbs so you need to look at the package carefully to see the difference. The Nu Tone and other special bulbs may still be available in the old filament style for a while but you may have to look harder or ask if they are still available. The amount of flicker often reflects the quality of the bulb. It will sometimes decrease over time.
Mar 02, 2015 | Dryers
Jerdon products jgl9w directions to change light bulbs
This vanity mirror uses (2) 9-watt fluorescent bulbs, which should last for the life of the product. The light is manufactured with the old-fashion preheat ballast tubes. In order to light the bulbs you must hold the "ON" switch DOWN for 5 to ten seconds then the lights light and you let go of the switch.
As for changing the bulbs, I'm not familiar with this product, but if I had to guess, the clear plastic front covers over the bulbs probably just snap into place. Removing the covers should give access to the bulbs.
Apr 12, 2014 | Home
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
My ceiling fan has a halogen(I do believe,it is about the size of my thumb and costs about $8.00) light. It stopped lighting and it would just glow orange. I replaced the bulb, and nothing changed. Is...
That bulb MAY require a 12V. power supply.Inside the fan housing.
They overheat and just go bad.
The socket may have overheated and damaged the contacts that the bulb must have.
The bulb has a number on it and that is the key-ask the hardware person about that bulb.
"Google" the number,also.
That's easier.
Jan 18, 2013 | Dryers
Replacing old flor 48" tubes
There are three types of fluorescent 48" bulbs t 12, t8, and t5. they are not interchangable. if you have a fixture that has a t12 type ballast, it will not light up the t8 bulbs. you have to change the ballast to a t8 style. just to clarify, the number stands for 10ths of an inch in diameter on the bulb. a t12 is 1.2 inches, a t8 is .8 inch and a t5 is .5 inch.
Nov 20, 2010 | Microwave Ovens
Garage door opens and closes,light bulbs have been changed, light does not come on when door opens and closes
Unplug the unit and remove the light bulbs. Using a small screwdriver pull out on the center contact in the light bulb socket.
Oct 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
No picture and buzzing sound on Sony XBR Wega
Is the bulb light flashing ? - Sony's bulb light is very accurate in telling you if the bulb is bad. The buzzing sound could be from the balist trying to strike the lamp. You also may want to open the lamp door and see if the bulb is shattered.
Aug 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Bulbs constantly burning out
are you using regular bulls or appliances bulbs also what id try is a couple of the screw in fluorescent bulbs they are just as bright but draw less amps most have a 5 year grantee
Jan 19, 2008 | KitchenAid KHTU100K Kitchen Hood
Light bulbs burning out
That does sound odd! On one hand, I would suspect that maybe the door is getting slammed and that vibration may be contributing to the failure. But that would be much more likely for an incandescent bulb than a fluorescent type. Which is yours? You may have a bad connection on the socket which is causing some excess heat. Does the blown bulb look funny on the ends or at the connection? Assuming you're using the bulb your manual calls for, and the socket is okay, it may be a problem on the control board. Once you've digested this reply, let me know what you find and we can take it from there.
Oct 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Garden Logo
792 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
