Lg wm3988h end of wash cycle water standing
I am wanting to set washer and let it go . ie wash then dry on its own. User's guide not any help .when it finishes wash cycle ends up with at least gallon water in tub and says its finished . yes it does drain well while running and i selected high spin. just purched today. thanks kyle
  • 2,427 Answers
Hmm take the hose down and lay it a bit lower than the machine it self.
Posted on Dec 29, 2008
  • 177 Answers
It might not have that setting, but if the online manuals doesn't help then try fiddling with the settings, who knows what you might find!
--P3NGYJ03
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
Washer/Dryer
weak pump...but remember in the drying cycle water is ment to come in and flush out lint and produce air flow for drying..it also cools drum..
Dec 16, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
