Question about Toshiba 27A33 27" TV
Only see a slice of picture + bright horizontal band
I get a bright horizontal band plus what looks like a more-or-less properly proportioned, 2" high section of the picture directly below the band. It looks like I'm seeing a narrow window of the entire picture. Color and sound are fine as is the small section of the picture that is visable. The window I see is a tad short in width, but otherwise OK. I have already replaced the vertical IC (Sanyo LA78041) and the 2SD2499 transistor on the same heat sink, which had no effect on the problem. My next step is to check all the related vertical caps around the circuit. Any other suggestions?
  • Charlie Talbott Apr 30, 2007
    Techman. Thanks for the advice on the two small caps. Could you please be a little more specific as to which ones? I've already checked about half the various ceramic and electrolytic caps in the vertical circuit and haven't found any bad ones yet. Unfortunatey, I don't have a schematic of the set, so I'm starting out at a disadvantage, but I feel there's only so many components in the vertical circuit.
    One more related question. I have completely removed the main circuit board. Is there a way to power up the board without energizing the High Voltage? That way, I cound more easily use a scope to poke around the board. I'm a bit gun shy of trying that with the set on now. (Yes, I know about isolating the ground lead. I used to work with 3 phase 480VAC/600 Amp SCR circuits.)
  • Charlie Talbott May 01, 2007
    I'm starting to feel really stupid about now. What exactly is the Y/c IC?
  • 4 Answers
Usually the 47 to a 100 mfd electrolytic capacitor although rarely the 1000 mfd 50 volt generally in and around the vertical output chip also just checking these capacitors may not reveal the defect so many times they may test good when they are bad the best way use substitution with jumper leads connect test shut off set go to next suspect turn set on .continue this you may find culpert.
Posted on May 02, 2007
    President:
  • 3,130 Answers
There are two small capacitors that need to be changed in the vertical circuit.
Posted on Apr 28, 2007
  • Larry  Dillon
    Larry Dillon Apr 30, 2007
    The capacitors should be by the Y/c IC and might be the black and red ones
    Genius:
  • 1,074 Answers
You could do three of these change flyback change yoke change cap that couple the horizontal transistor.good luck
Why does 1/5 + 1/2 not equal 2/7?
Let's look at the overall picture. Does it make sense if you have a fifth of a pizza and add a half pizza, you get less than a third of a pizza.
Now, into the math.
Here is a fifth of a pizza.
fifth pizza-t3nl2udzxv0orsigcra1nwzp-2-0.jpg Here is half a pizza.
It is hard to add these two.
We find the least common multiple of the denominators 2 and 5 and get 10.
Let's redo the pizzas in 10 slices.
And the half pizza.
Now with the same sized slices, we can add the slices and calculate the result.
seven tenths-t3nl2udzxv0orsigcra1nwzp-2-14.jpg Now we have seven slices out of ten, or 7/10.
Good luck.
Paul
Jan 04, 2017 | Homework
AKAI Colour Television CT-1419A/AT plus AKAI remote RC-V9A. Television was fine, then went to just a narrow, bright horizontal band across the screen but sound is fine. Suspect my son played with the...
hi,
Its not problem with any setting. Its an internal fault. Vertical scanning output stage has failed in your tv. You have to check the soldering of the vrtical output ic if there is any dry soldering this can happen. try to resoder all the points in the vrtical output stage. IF doesn't help then you have to change the vertical output ic. Have added the picture of the dry soldering point how it looks like. If you need further assistance feel free to contact throug FixYa.
Aug 20, 2011 | Akai Televison & Video
Virtical picture cut on the screen about half inch.
Depending on the monitor, you can try looking for an "Auto-Adjust" button. Pressing that should automatically realign the screen to it's proper proportions. If not, the monitor should have a menu where you can locate options to adjust the horizontal and vertical zoom, as well as position.
Mar 29, 2011 | Computers & Internet
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Mar 01, 2018 | Dell Computers & Internet
Sony KV-27FS200 bright horizontal line problem
try to replace all filter capacitor on vertical section area that can solve your problem.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony KV-24FV12 picture problem
Alright, TV has hardware problem in Horizontal section and I would suggest to set Picture Quality as Soft Mode.
Jun 20, 2008 | Sony KV-24FV12 24" TV
Tube TV - one thin horizontal line of bright light
Vertical defection failure. Common failure. Pretty easy to repair ($50-75?). However, my general rule of thumb is not to waste any more money on TVs over 10 years old. Too much other stuff in there ready to fail as well.
Jan 24, 2008 | Televison & Video
Horizontal bands
you may have a problem with the vertical output IC.
May 26, 2007 | RCA F27442 27" TV
Stationary horizontal lines
Thjeres a problem with the screen voltage driver voltage capacitor or the crt is going bad. have the shop test the b+ on the crt board first off . then remove the crt board and see if the voltage comes up. If it does the capaicitor is bad as it can take the load. But remeber theres extremly hi Voltage inside these sets so its never a good idea to try to do this your self unless you have the training to deal with HI Voltage and the proper saftey and test equipment. Good Luck
Jun 21, 2006 | RCA F25655BC 25" TV
Toshiba 27A33 27" TV Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
