Question about Lexmark N2050 for X3350 (14T0300) Wireless Adapter
Lexmark N2050 wireless adapter for X3500-4500 series printer
I have worked all day on this. Installed wireless adapter according to directions. Set up wireless router for new laptop as directions dictated. Wireless internet is working, but can not print to the lexmark. It's wi-fi light still glowing a constant orange. I'm exhausted. Installed printer driver in new laptop from printer disk. Still have desktop computer connected to printer via USB. Please help, what have I missed.
    Problem Solver:
  • 11 Answers
I cant tell you too much because i dnt know too much about your situation but try completely resseting everything and try sending something again
if its allwireless c if you can pick up the wireless points if you cant there's your problem
Posted on Jan 01, 2009
No CD to install.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Jul 09, 2010 | Belkin BLKF5D8053 (00312328000P) Wireless...
The wireless network is being picked up by the laptops in the house, but there is no internet connection between the modem and the router. MY router is a Belkin G Wireless
if you connect the computer directly to the modem, does it work?
Mar 06, 2010 | Belkin Wireless-G Plus MIMO Router with...
How to install belkin wireless mouse in a laptop?
Mar 06, 2010 | Belkin (F5D7000) 802.11g/b Wireless...
Running install disc, says does not support operating system
Mar 03, 2010 | NetGear WGR614 Wireless Router
Brought a new laptop with wireless installed have a philips SNB5600 but have lost the security key how can i get the code
go to the wireless access point admin settings (not on your wireless adapter on your laptop). then check wireless security settings. if you see something there such as security key, that is the security key that you need to set up on your laptop. if security key is not visible, try to see if there is an option there which says unmask to show the security key, then copy it to your laptop. if all else fails, change the security key in the wireless access point and change all the wireless adapters that connect to it accordingly to the new security key you set it up.
Nov 07, 2009 | Computers & Internet
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
D-Link 615 stopped connecting with wireless
If your laptop is not detecting the wireless router, can you try to get the laptop closer to the router ? If you have done that already, I would suggest you to try and power cycle the router once. If that doesnt work either, try to reset the router. Hope this helps
Thanks Ranjit ranjit@supportminds.com
Jun 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
New netgear adapter on my laptop & can't get on the internt
I think you need to set up you home wireless network on your laptop again. I asume you set it up with your first adapter, but you need to set it up for the new adapter. If this doesn't help, include OS type on laptop. Then I can give a better solution.
May 25, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Can't connect home comp to laptop
how many wireless computers do you have?
is it a dekstop or laptop?
if desktop have you installed a wireless adapter? if laptop, is it using a built-in wireless adapter, have you enabled the wireless adapter or have you installed a wireless adapter?
please make sure first that the wireless adapters are installed properly or enabled on your computers, if everythings OK.
access the setup page of your router and change the wireless settings of it.
how to access the ui
- open the internet explorer
- on the address bar type in 192.168.1.1 hit enter
- enter admin under password, leave it empty for the username and click ok
- click the wireless tab
- set the wireless mode to mix, change the wireless network name or ssid with any preferred name you want to use, make sure to enabled the ssid broadcast and then click save settings.
- after that, under wireless tab, there are sub tabs, click wireless security
- set wireless security to WPA-PERSONAL, and under passphrase, enter your desired password for wireless connection, take note of it and please be reminded that its case sensitive.
- click save settings.
for your wireless computers, if adapters enabled and working fine, on the system tray you should have an icon for the wireless connection, doubles click on it and it will pop for the wireless connection window wherein you can see the name that you set on your router, all you have to do is select the name click on connect and it should ask you enter a password, enter the passphrase you set on the router and click connect. then check if you can go online, if yes do the same thing with other computers.
Have a great day ahead.
Sep 28, 2008 | Linksys WRT160N Wireless Router
Laptop.. cannot connect to internet
if you want to use wireless connection you have to have a wireless router, and you connect your internet cable into the router, so after you can have a wireless connection with your laptop and his wireless card, and you can work with your laptop everywhere in your house.
you can buy a wireless router in every computer shop.
last thing if you have a desktop PC you can connect a new internet cable to the wireless router (type RJ45)
I hope this helps
Please rate accordingly
Thank You
sserpentio
May 03, 2008 | IBM ThinkPad T30 2366 Notebook
Lexmark N2050 for X3350 (14T0300) Wireless Adapter Logo
799 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
