Computers & Internet Logo
Posted on Dec 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black screen after BIOS update
Have a NEC versa m540 laptop tried to up date the BIOS and now have a black screen.Checked I had the correct exe. file before I started.
Matthew Spark
Level 3:
Genius:
  • Master 1,066 Answers
  • Posted on Dec 29, 2008
Matthew Spark
Master
Level 3:
Genius:
Answers
1066
Questions
Helped
298165
Points
2431
Better flash the bios again, this time try a different version of the bios. but, if it wont boot from the new bios flash disk, then u just turned your computer into a paper weight.
Black screen on acer aspire 5560 series will not load
Fix 1: Power reset your laptop
Power resetting does a trick to fix the Acer black screen issue and it works for many people. Here's how to do it:
1.Turn off your laptop.
2.Remove the AC adapter cable, hard drives, the battery and any other attached peripheral devices.
3.Press and hold the Power button for 30 seconds and release. Your laptop will boot up and turn off during this time period.
4.Put your battery back in and plug the charger. Then don't plug anything else.
5.Press the Power button as normal to turn on your laptop.
Your laptop should start normally now.
If this method works for you, you should update your device drivers to the latest version to prevent similar problems from happening again.
If the laptop screen is black, don't worry. There are other solutions.
Fix 2: Try F2, F9, and F10 key
If you find yous Acer laptop screen is black, you can try this:
1.Ensure to turn off your laptop, and unplug any external devices.
2.Press the Power button to turn on your laptop.
3.When you see the Acer logo or splash screen appears, press F2, F9, F10, and Enter key on your keyboard.
4.Select Exit > Yes, and press Enter.
Your laptop will start and the black screen issue should be resolved.
Fix 3: Update graphics card driver
The missing or outdated graphics card driver in your laptop can cause the black screen, so you should verify that the graphics drivers in your laptop are up to date, and update those that aren't.
Note: You'll need to log into your computer to perform these method. If you can't log into your computer, boot your laptop into Safe Modewith network, then follow the instructions below.
You can manually search for the latest version of your graphics driver from the manufacturer, and download and install it in your computer. This requires time and computer skills. We recommend this if you're confident with your computer skills.
If you don't have time or patience, you can do it automatically with Driver Easy.
Driver Easy will automatically recognize your system and find the correct drivers for it.You don't need to know exactly what system your computer is running, you don't need to risk downloading and installing the wrong driver, and you don't need to worry about making mistake when installing.
1.Downloadand install Driver Easy.
2.Run Driver Easy and click the Scan Now button. Driver Easy will then scan your computer and detect any problem drivers.
3.Click the Update button next to the flagged graphics device to automatically download the correct version of the driver (you can do this with the FREE version), then install the driver in your computer.
Or click Update All to automatically download and install the correct version of all the drivers that are missing or out of date on your system (this requires the Pro version - you'll be prompted to upgrade when you click Update All).
4.After updating, restart your computer to take effect.
Check and see if your laptop screen works properly.
Fix 4: Check for virus and malware
Note: You'll need to log into your computer to perform these method. If you can't log into your computer, boot your laptop into Safe Mode with network, then follow the instructions below.
Your Acer laptop screen may be black if your system has been damaged by virus or malware.
So run a virus scan across your entire Windows system. Yes, it may take some time to complete, but it's worth it. Unfortunately, Windows Defender may not detect it, so it's worth trying another antivirus program such as Avira and panda.
It any malware has been detected, follow the instructions provided by the antivirus program to fix it.
Then restart your computer as normal and see if it fixes your black screen issue.
Fix 5: Update BIOS
BIOS stands for Basic Input Output System. It's a software that is stored on a small memory chip in the Motherboard of your computer. BIOS is used to identify and troubleshoot the hardware issue in your computer or laptop.
To update your BIOS, go to Acer support page, find the BIOS file for your Acer laptop model. Download it into your USB drive, and follow the instructions provided by Acer to update BIOS.
2answers
Nec vy17m/r-1 audio is not working
Hi Neil
Update to the latest drivers, if you already have the latest drivers, update then anyway, this may fix your issue.
Support Downloads
Andrew
Hp bricked after bios updates hp pavillion dv9700 need help please
hello,
this indicete that you did not do properly the update,my advice is to restore the old bios if you backed up if not try to do again the update
1helpful
How do i repair nec versa p9120 wifi on power on fan is running but i have a black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
HI. I ve a NEC versa pro VA12J. When i start my laptop it starts with beep sound and shows BIOS screen with an error message: 0251: system CMOS checksum bad- default configration used. During this period,...
This "0251" error indicates that the CMOS (complementary metal-oxide semiconductor; a memory chip that holds data the computer needs each time it starts, such as the current time and the BIOS [Basic Input/Output System]) has become corrupted or damaged, typically because of one of these three reasons: A BIOS update has gone awry, a recently installed program incorrectly modified the BIOS, or the computer battery is running out of power.
If you recently upgraded the BIOS, the first thing you should do is edit the BIOS settings. The BIOS developer can help you access the BIOS Setup utility and configure the BIOS accordingly. Likewise, if you recently installed a program that may have modified the BIOS, contact the software developer for assistance in reconfiguring the BIOS for the new program.
If you did neither of these things, the culprit is probably a faltering battery. You can probably replace the battery on your own, but the process varies widely depending on the type and age of the computer. We suggest consulting the documentation that came with your computer or contact the computer manufacturer to determine the type of battery involved, where to purchase a new one, and how to replace it. You can also access the BIOS Setup utility and write down the BIOS settings to reconfigure the BIOS correctly after installing the replacement battery. Once the new battery is in place, you will have to reconfigure the BIOS and reset the system time, but the error message shouldn't appear again.
hope this helps
2helpful
2answers
Forget bios password on nec laptop versa
The BIOS password may be removed by removing the BIOS battery from the notebook for 20 mins. If you cannot wait for this period, then short out the battery contacts for a few secs.
Replace the BIOS battery and go to the BIOS configuration and set the Date & Time etc.
If this procedure does not work then try this WEB site for BIOS passwords :-
http://www.biosflash.com/e/bios-passwords.htm
1helpful
Don't know boot up password. How do i go about unlocking it. Nec versa m540.
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
2answers
Need help with my laptop
Did you laptop come with a RESTORE CD or DVD?
Look for the application on the media that came with the laptop.
You can also get it online
ONLY for AMI BIOS and Windows NT 4.0.
ftp://ftp.necam.com/pub/Catalog/3620/HDPrepNT.exe
HDPrepEZ version 1.9 for AMI BIOS. Supports FAT32 partitions.
Windows 95, Windows 98
ftp://ftp.necam.com/pub/Catalog/3646/Hdprepez19.exe
This is the page with all support downloads for your LapTop:
http://support.necam.com/downloads/
Select you type / make / model and you will have access to all service releases.
Hope it helped.
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
