Question about Kenmore 64902 Electric Dryer
Dryer tumbler won't turn but heats up
The dryer heats up but the tumbler won't turn. I went to sears and got a belt but the belt wasn't broken. what should I do?
That was the problem thanks.
Posted on May 03, 2007
    President:
  • 1,462 Answers
Turn on for a short time and listen for a low hum. if present, this means the motor is stalled. take of top and give the drum a push. if it then starts to run then the motor capacitor is faulty
Posted on Apr 27, 2007
Dryer wont tumble
Probably a broken belt. Remove the back panel and see if the belt is still around the tumbler. You might pull on it and see if it is broken.
Oct 11, 2014 | Dryers
Heats but tumbler is not turning
it sounds very much like the drive belt has either come off the drum or broken but usually they will not heat if this happens as their should be a safety switch so when the belt breaks it switches the heat off so it would be better if you have it checked by Sparky
Oct 08, 2012 | Roper REX4634KQ Electric Dryer
Dryer heats up, but tumbler won't turn.
Hello awe.... when the dryer heats but doesn't tumble it is due to a broken dryer belt. It is always a good idea to replace the idler pulley when you replace the belt.
IF you want to do this job yourself you can see a schematic and order the parts at searspartsdirect.com
Joe
Feb 22, 2011 | Maytag Dryers
Maytag gas dryer broken tumber belt. how do i replace it myself? the tumbler doesn't turn, the belt thah goes around it is broken. i need to put a new belt on.
Each dryer is made differently on how to access the drum (tumbler) and belt replacement. If you can provide a model #, that would be very helpful. On most dryers the model# is located on the door frame usually to the left when you open the door. This will get you started in the right direction.
Mr Tin Man
Dec 19, 2010 | Maytag Dryers
Dryer runs and heats up but tumbler won't turn
The belt is likely broken. To be sure turn the dryer on and listen if you here the motor running the belt need to be replaced http://appliancehelponline.com/dryerbeltvideo.html If the motor is not running it could be a few other things and this link should help
http://appliancehelponline.com/edryerheatsnospin.html
Jul 13, 2010 | Magic Chef CYE2000 Electric Commercial...
Maytag electric dryer. Tumbler won't turn.
The first thing to check is the drive belt. you will need to turn the dryer on its side and look to see if the drive belt is broken. If this is o.k it will be the motor.
Dec 08, 2008 | Dryers
Dryer problem
I could be wrong, but I don't know of a dryer that DOESN'T use a belt to turn the drum. If the motor is turning on, and the drum is not spinning, more than likely your suspicions are correct and the belt is broken. You can find a replacement at searspartsdirect.com. Just type in the model number you have provided and look under the "Tumbler" heading for item number 5 (part #341241). The website also offers some helpful exploded view illustrations to assist in part location and installation.
Repairclinic.com carries the part at a cheaper price (item number 529597). Use the part number provided by the Sears website for your search criteria. Repairclinic also offers dryer belt installation diagrams. Just click on the "Repair Help" link at the top of the page and look under the "Special Features" section on the following page for "Dryer Belt Diagrams". Magic Chef uses diagram F. I hope you find this information helpful. Let me know if you have any questions.
Oct 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Broken belt that turns the drum
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Kenmore 64902 Electric Dryer Logo
133 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
