Question about Whirlpool GD5SHAX Side by Side Refrigerator
With frig door open the light is not illiminated and the digital settings are not lit. There is a clicking sound that stops when the close door button is pressed. Removed light and tested in another device and it tested good. Is there a fuse or other item that is easily replaced?
  • deitzgen Feb 05, 2009
    do you have the part number replaced?
    Problem Solver:
  • 5 Answers
In the back of the unit next to the compressor is a little white box. It has a circuit board in it. I moved the unit out took off covering and put my hand on the white box. I could feel it vibrating and so I went to and got a new circuit board, and problem fixed. I think the part was around $90.00.
Posted on Feb 05, 2009
My remote opens my garage door but will not close it. It starts to make a clicking sound when the remote button is pushed to close the garage door. It is a chamberlain Liftmaster with wireless key pad....
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flashing. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
When I click my remote to close my garage door it just clicks and the light flashes, but it won't close. To close the door I have to hold down the button on the wall unit until it closes. If I stop holding...
Make sure the door sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor or bad wiring to them.
Nov 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door opens when i push to open but when i push to close it starts to close until i stop pushing the button. When i release the button the garage door opens back and clicks 10 times
Check the door sensors. They must be pointed at one another and the small light on each one must be lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have either a bad sensor or the wiring to them is shorted or broken.
May 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door opens when i push to open but when i push to close it starts to close until i stop pushing the button. when i release the button the garage door opens back and clicks 10 times
Check your door sensors. The need to be pointed at one another and make sure the small light on each one is lit and not flickering. Tweak them a bit. If you can't get both lights to come on one of your sensors has failed.
Mar 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
My samsung frig suddenly started clicking (the bell that lets you know the frig door is opened.) checked to make sure all doors were closed but bell keeps ringing and now the temp. is rising inside. what's...
Can you pull the gasket back slightly (flat screwdriver or dull knife, don`t cut/rip the gasket) from the side of either fridge door and tell me if the cabinet light is on inside ? I need to know if the light is on without opening either door.
I`ll watch for your reply.
macmarkus :)
Feb 04, 2010 | Samsung RF265AA Bottom Freezer French Door...
Lights out..White box is clicking in back base of frig
sounds like the relay box on compressor . . you can repl the relay . it's not a hard job .. and its lso a very common problem on many frig's . ****
Jan 04, 2010 | Refrigerators
Frig has stopped making ice.
Open the left door open the ice maker door, up in the left hand corner you should see a green light, check to make sure that you have a selection chosen(either small of large cubes.
Jul 15, 2009 | LG LFX25960ST Stainless Steel French Door...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the pilot.as long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
Light not going out in viking frig when door is closed
you have a micro switch at the top of door by the door hinge.must remove top vent cover to access. i've found that if the screws (2 or 3 phillips ) get loose the door is not aligned to open and close the light switch . or maybe the switch itself has failed
Nov 26, 2008 | Viking 24 in. Professional Series VUD141...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
