Kenmore Elite Oasis Model 110.27072600 Wigging out
I have read your solutions about replacing the control board on the above model to fix the relay from shorting out. I thought it made sense, so I had took it apart today to try to have a look to make sure I could get the CB out. I cannot figure out how to get the white wiring harness off the control board. There are two screws in the middle (i removed them) but it is not intuitive to me how to get to the board from there. Any ideas?
  • pschlabach Dec 31, 2008
    First of all, thanks for your detailed response. Your posts are very helpful.
    That is the cover I was speaking about and I will give this a try. I have studied the illustration from searspartsdirect in detail, I just could not figure out how to get the cover plate off. I was going to wait to order the UI board until I was sure I could get to the board itself.
    My real question is which board to replace -- The “Control unit assembly, machine& motor” (part 1 on the diagram) or the User Interface board (part 7 on the diagram). A previous post to FixIt just said I had a bad control board, (not sure which one he was referring to).
    The washer is displaying all of the following symptoms. 1. Constant beeping 2. The washer turning on by itself and displaying F2 codes after the washer has been stopped and turned off. 3. Wash times changing every second as the load is completing. (flips between 42 and 53 on a normal wash and then counts down from there). 4. Other sundry error codes showing up at different times. Very bizarre behavior from such an expensive appliance.
    Any thoughts on which board might correct the problem? Or will I have to replace both of them.
  • 5,911 Answers
The user interface is covered by a cover plate. There are a series of tabs that hold this cover in place around the perimeter of the control board. Use a small screwdriver to carefully pry the tabs back (one at a time). Also, you have to remove the control knob form the front panel, first, before the board will come out. There's an illustration you can use at searspartsdirect.com. Just type in the model number you provided and look under the "Control Panel Parts" heading for item number 10. This is the user interface cover that I'm speaking of. There is only one small wire harness to speak of that goes to this control board. Is this what you are talking about?
Posted on Dec 29, 2008
  • Jeff Rockwell
    Jeff Rockwell Dec 31, 2008
    The constant beeping and erratic display is caused by the User Interface board (part 7). This is a noted and common problem with the Oasis.
KENMORE DRYER # 110.67042600 CODE F1 , CAN THE THERMITER BE SHORTED OUT
F 1 error code flashes, when there is a primary control board failure. To fix, the "F 1" failure the machine control board will need to be replaced. Not cheap part.
press the helpful button and follow me on fixya for more info and tips
Kenmore Dryer Model 110 67042600 11067042600 110 67042600 Parts
http://www.appliancepartspros.com/parts-for-model-kenmore-11067042600.html
Kenmore Elite Oasis electric dryer problems Sears PartsDirect
Feb 03, 2016 | Kenmore Dryers
Need to replace control board for my kenmore elite oasis 27087 washer. Am trying to find out what the correct part number is?
you need to get the complete model number
Tips for finding your unique model number
  • Look for your model sticker, tag or plate.
  • Include every digit in the model number, even if some are sized or styled differently.
  • Kenmore and Craftsman model numbers typically have three digits separated by a period.
Then go to http://www.searspartsdirect.com/partsdirect/index.action
and they will show the correct part number and you can order from them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 14, 2011 | Kenmore Oasis HE 27087
Kenmore elite model #110-67042601 is flashing a AF code
The AF error code for Kenmore Elite Oasis dryers with model numbers 11067032601, 11067042601, W10035200, 11067032600, and 11067042600 indicates that the dryer is experiencing an airflow problem. The Kenmore Elite Oasis owner's manual recommends four troubleshooting solutions to an airflow problem: clean the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Read more: Error Codes on Kenmore Dryers ' eHow.com http://www.ehow.com/list_7192588_error-codes-kenmore-dryers.html#ixzz1MuOgWsZC it is found also on this link above by clicking the link if you have any further questions please message me back and your dryer should be dlinted at least once per year to avoid dryer breakdown you can also see how to dlint your dryer by clicking this tip that I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer I await your reply if you have any further questions Thanks Rick
May 20, 2011 | Kenmore 72982 Gas Dryer
What does code F1 mean for a Kenmore Elite Oasis model 27032?
Here is a link to some good information on your error code. This should explain the error code you have.
http://www.theworldofwashers.com/2009/03/reader-mail-f1-error-code-on-kenmore.html
Nov 21, 2010 | Kenmore 27032
Kenmore elite oasis washer has error code f1
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis HE 27082 Stainless Steel Top Load Washer: I have KENMORE ELITE Oasis He and it kept repeated...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
May 18, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis dryer model #110.6708 will not operate. flashes f-40. what does f-40 mean?
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have kenmore elite oasis, type 580. when starting
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
575 people viewed this question
Top Washing Machines Experts
