Question about Brother MFC 420CN All-In-One InkJet Printer
Same problems as others...
I to am having the same problems with my mfc 420cn.I can't send or receive a fax. It keeps telling me that receiving fax machine is busy. When i know that's not the case. I tried for 3 days with it.No luck yet. The salesperson where i bought it,says if it were her she would go with this brand over the others. I have always used HP, and never had a problem. Boy do i feel like a fool for going elsewhere now. I am so frustrated with this mfc 420 that i just want to throw it in the trash, or give it away, but then i don't anyone else to have to go through all the problems that i did to even get it to print right.. So now i am out almost $100.00 on something that wont work right, now i can't even get my money back on it. Any help out there for this machine? It would be appreciated. I run my own business from my home and I have to have a printer/copier/scanner/fax the whole 9 yards..
  • 43 Answers
The brother printer is not a good brand i also have a brother mfc 3220cn and it gives the same problem, what you have to is unplug the machine and let it stand for about 2 days take out the cartridges and clean the printing with air replace back them and plug in.that should remedy your problem.i urge on you never to buy brother printers.if you buy them get a bottle of phensic along with it.good luck my brother*
Posted on Apr 27, 2007
How to disable my fax/tel mode? I can't receive any messages, because the fax keeps coming on after the third ring?
Disable the FAX auto-answer
Press the FAX button
  1. Menu/Set, 0, 1
  2. Use the up/down arrow to select Receive mode to be "Manual"
  3. Press Menu/Set
  4. Press Stop/Exit
Manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057875.pdf
Mar 15, 2011 | Brother MFC 420CN All-In-One InkJet...
How do i hook up to use fax machine?
put a phone wire from the line jack on the machine to the wall. like this you should be able to send
to receive put the machine in fax only receive mode and only connect the phone wire when you know there is a fax coming in bacause in this mode it will answer every call like a fax
Mar 23, 2010 | Brother MFC 420CN All-In-One InkJet...
How do i use the fax machine
Follow the way.
1. plug on you phone connection with your all in one machime.
2. Then On the all in one machine.
3. Dial no getting tone from other side put your paper in top side copier place.
4. receiving fax make your fax receiving setting automatic. in will came out.
*** But remember before use it you must activate your phone connection for sending & receiving fax. FOr these you have to contact with you phone connection company."
Thanks & waiting for your feedback
Jan 31, 2010 | Brother MFC 420CN All-In-One InkJet...
Unable to make and...............
it should not give you any problem if you configure dial up properties of MFC
Apr 02, 2008 | Brother MFC 420CN All-In-One InkJet...
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Fax does not receive or send
plz contact brother hotline of your country ( www.brother.com )because there are so many diffrent telephone standards which might affect a good working of the fax abillity.
Jan 31, 2008 | Brother MFC 420CN All-In-One InkJet...
Not receiving faxes
So if you have no noise, its a prob of the tele company not of the mfc!
Or did the tel company change to another tel standard instead of your former type?
You have to talk to the tel company to get that clear. Ask for the line standard bein g used (ISDN, normal, or a special tcpIp).
When you got the info call brother hotline of your country for support. They will help you with that prob.
Jan 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Receiving faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Printer keeps turning off,,,error message MN1 in lcd
I realise this is an old question but I recently had a similar issue with our MFC-5860CN not receiving faxes and displaying the "Mn1" code. As it turns out "Mn1" means the machine is set to manual receive and was therefore not automatically receiving faxes. You will need to locate the "Receive Mode" option in the menu and change it to "Fax Only" or "Fax / Tel". Unfortunately I dont know what could have caused the turning off and on that the OP mentioned. I'm a little late to the party but I hope this info can help someone else!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
90 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
